warming up or pre conditioning doesn't make the car more efficient. It increases range by using wall power to get things up to temp before you set out on your trip. Unless you need max range it isn't necessary.
Now if you want to be comfortable or if you need to defrost windows etc. then you will need to "warm up". Otherwise just get in it and drive.
How so? Your just using wall power to heat things up if your plugged in. If not wall power your reducing your range. I think you mean it gives you more Regen and higher power output. It doesn't increase efficiency though.Warming the battery makes it operate more efficiently.
Only when its freezing out.Warming the battery makes it operate more efficiently.
Right but the energy used is still the same. Your just taking it from the wall instead of the battery. What I'm trying to say is that it's not more energy efficient to precondition the car.Preconditioning while plugged in results in more efficient driving because the passenger cabin is already at the desired temperature and the battery may have been partially warmed. Especially for short trips of less than ~25 minutes the Tesla Model Y will not have use as much energy while driving to maintain a comfortable cabin temperature.
