And right on cue, this right here is exactly why I warned against that. It is offering a fake 50 amp outlet that has no business being there, and relies on people to set the amps to whatever they think it should be. (Really, I put about two thirds of the blame on the company for selling those at all.) And in this case, the person got it pretty close, but still wrong. For a 30A rated circuit, that should be no more than 24A, not 25A.
The car remembers it...until it doesn't for any of a few reasons. Software updates have been seen several times to make the cars forget their memorized amp settings. Also, I've personally had this one happen to me--the car keeps that setting tied to a GPS location. Sometimes the GPS signal is messed up or off for some reason, and it thinks the car is a couple blocks away from your house, so it doesn't think it is at that "25A" location, so it defaults back up to 32A, overdrawing the circuit. If you are fortunate, and the breaker trips as it should, then your house doesn't burn down. If the breaker fails, as they sometimes rarely do, you have a Problem.
So using the correct 30A Dryer Buddy for 30A outlets makes you use the proper 30A Tesla adapter, which forces that 24A limit and doesn't depend on the car having the GPS position always right or risks an update deleting the memorized amp setting.
