MyEarHurts
Banned
Yeah the hatch does seem to cause the boominess and is very sensitive to any adjustability. I don't have pics of the stoppers but I used the pvc end cap method, I'll try sanding them down to lower it a tad more.I wish I could take a drive in your Model Y and assist you with this. The butyl will help road noise which is part of the low-freq spectrum, but at the end of the day, ANY movement of the rear hatch door will contribute the most to any headache-inducing booming. If the stoppers are somehow not adjusted properly (too much, too little, too uneven from one side to the next), you'll probably run into problems.
I forget have you posted pictures of your stoppers? For what it's worth? Are you using any kind of rigid hatch stops? For some reason I still don't understand is how you had a ginormous gap with 5/16" OD tubing.
I just did this again to the Oct 2022 delivery Model Y I wrote about earlier, and the driver said he noticed an improvement. I noticed it as well. Regrettably, I didn't record measurements with Spectroid before and after.
As for the tubing, to clarify, the 5/16 tubing fit the seal, I was talking about me having ADDED additional seals to the left and right side along the the body of the car where the hatch rests. I put the seals there and inserted tubing in which caused the hatch to have a large gap (with the seal squished) is what I meant, I guess not really a gap but more like it raised the hatch?
I will try it again when I get a chance, I figure this would give it more of a seal and if anything to keep the dirt from the tracks. Do you think adding butyl to the hatch itself would make a difference?
