azeteg
Yeah I may need to revisit this. I will find something else for this location.Of course this is not as serious as in wheel well because there the moisture and road salt combination may cause rust.
Sounds like you have done quite a lot already.Thank you for opening you sound deadening process and thoughts. Do you have any ideas that I could try next?
What I'll be trying out myself, is to attach a BMW branded tuned mass damper (33Hz) to some resonance points to see if it helps to reduce the 30-33Hz peak we are experiencing. Not sure about the Q factor of this one, but it should be wide enough to at least help a bit below 33Hz. I should be receiving this (used part) today or tomorrow. I'll of course report my findings here.
