zax123
CDN Model S 100D
Hmmm... At the rate they're going, you may be pleasantly surprised!Maybe I can fill in for Doug this time around. I've got a trip to Toronto on Dec 4th, so it'll probably be done the week after that.
I have to be in Toronto from Montreal on December 22 so it'll probably be ready the week after that.
A little birdy told me today that Kingston will be done by the end of November.
Also, Woodstock will follow shortly.
Nothing concrete to report about Barrie.
I was told Drummondville will start "soon"...which could mean anything in Tesla time.
I also heard that Drummondville would start "soon..."
we were told that a number of times ...
I can make the claim (which I believe) that I heard from a reliable source, but until there are pictures of a site under construction, it is all just hearsay... :crying:
It may already be dropped to 600 for the shopping center. The supercharger site will likely be fed 600 from there. Tesla would be required to supply the 600-480 drop.
Where is the Woodstock one going to be? Is it in the rest stop(s) on the 401 between Woodstock and Ingersoll or will you have to get off the hwy?A little birdy told me today that Kingston will be done by the end of November.
Typically these big box malls in Ontario have pad-mounts dedicated to the stores (or block of stores) they serve with each service metered at the secondary level. Typically this is 120/208 volts 3-phase, 4-wire, but 347/600 volt is not unheard of either. My guess is that a dedicated pad-mount transformer fed from the utility's primary (13,800 v and 27,600 v are common) would be used to supply the Supercharger.
Tesla SC crates are now on site in Kingston...
Even if you are one of the Hamilton / Stoney Creek / Grimsby 85 owners, you will be biting your nails to Kingston in the winter. Of course you could pull off in Toronto after only 80kms or so of driving and fight your way down to the Lawrence charger. I too support another charger in between Toronto and Kingston. Cobourg would be ideal IMHO. I totally understand why the other locations mentioned above are now a priority (bare bones east & western connections), but as many others have pointed out, there is some back-filling needed before our range concerns truly disappear.
