Much of the prior discussions/debate about creep mode have related to user preference or familiarity with ICE car behavior. But in light of recent accidents, I thought it be worth pointing out an important safety consideration.
First, answer the following question assuming creep mode is ON (same as an ICE car with automatic transmission):
You are in the driver's seat of your Tesla and suddenly become disoriented (doze off, pass out, seizure, brain fart moment). When you come to, you realize the Tesla is not moving but your vision is blurry and you don't or can't look at the screens. Which gear could your Tesla be in?
A) Drive
B) Reverse
C) Neutral or Park
E) Any of the above.
The answer is C.
You suddenly stomp on a pedal, either the brake or accelerator, either intentionally or unintentionally. Which outcomes are possible?
A) Car lunges forward at high speed.
B) Car lunges backward at high speed.
C) Car doesn't move.
D) Any of the above.
The answer is C.
Now, answer the same question assuming creep mode is OFF.
A) Drive
B) Reverse
C) Neutral or Park
The answer is D.
The answer is D.
So, in summary, with creep mode ON, you have a very predictable experience with regard to gear and car behavior when the car is not moving. But with creep mode OFF, any sort of disorientation and suddenly you might not be able to tell what gear you are in and not know what might happen if you stomp on a pedal either intentionally or unintentionally.
A) Drive
B) Reverse
C) Neutral or Park
The answer is C.
The answer is C.
A) Drive
B) Reverse
C) Neutral or Park
The answer is D.
The answer is D.
