Anyone use or know a good cap/cover for the charger? I have found this so far:
https://www.amazon.com/Motors-Charging-Charger-Protective-Silicone/dp/B01EEZRQRG
same design, but use some nylon instead of metal chainHaha -- Thanks for posting pic. Definitely would just use the cap and no chain attachment. Maybe there is a better option out there though.
Wall connector and UMC are weatherproof, so not sure what purpose would something like this serve...
True, true. There's nothing to protect, unless you want to protect the outer edges of the plug if you drop the thing.
So I could take the connector, plunge it in a bucket of water, take it out of the water and plug it into my car to charge and it would be fine?
Why do you believe that you need some kind of "cap" or cover over the end of the charging cable?Anyone use or know a good cap/cover for the charger? I have found this so far:
Note: if you have a Tesla HPWC, either the type with the 24' cable or the 8.5' cable, and you hang the end of the cable in the included mounting spot, the end of the cable is covered and protected from rainfall. Also, you can buy one of these Tesla — Cable Organizer and place it wherever is convenient for you, and it will also protect the end of the cable.
