dgpcolorado
high altitude member
Why? My understanding is that the brake lights come on at a set deceleration rate (g force). If true, that doesn't have a direct link to kW of regen used at a given speed and I don't think the brake lights are controlled directly by level of regen. (I might be wrong about all that but that's what I recall reading about it.)It varies with your speed. At slower speeds, around -15 kW is about where they come one. At higher speeds, it's around -30 to -35 kW.
I'd love it if there was a small tick mark on the regen meter that moved with speed to show the brake light threshold.
If the car is decelerating at a rate high enough to present a hazard to the following car, the brake lights come on. At a lower g force they don't — much like the gradual slowing of a conventional car due to engine compression when one backs off the gas. Isn't that enough? What difference does it make what the regen level and speed are?
Have you considered that those numbers would be completely different on hills versus the flatlands? I descend steep hills using heavy regen but travel at a constant speed. I don't think that the brake lights come on, nor should they.
