hybridbear
How is the coolant routed for cooling the charger(s)? Is that a separate coolant loop? In the Focus Electric the coolant loop for the HVB is also the coolant loop for the onboard charger. This means that heat from the charger is transferred to the battery via the coolant. Additionally, the HVB also heats up from charging. If you're able to monitor HVB temps you'll notice that driving down a mountain and charging the HVB from the descent will raise the HVB temp much more than climbing the mountain does.Heat from the charger doesn't go into the battery, so I don't see the relevance of that.
