Totally agree with you on this. My interest is also to understand why some consider the realizing of these functions are now somehow "dangerous"? Let's take wipers...how is it dangerous to press the stalk and then select what you want to do with wipers? How is swiping up from anywhere on the bottom of the screen, to then select what you want to do with seat heaters, dangerous? It may be one more move (which you would do without looking!) but how is it dangerous? I don't care if people dislike v11, that's their right...but dangerous? That for me is laughable nonsense that I will continue to comment on.
Let me compare two use cases of common functions (probably not in Texas but in quite a few other parts of the world): defogger (arguably, it could be critical because it may require immediate attention) and seat warmers (not so critical because you can choose the moment to activate - unless your partner asks you to do it).
V10 defogger: Touching the icon, not looking. Full attention to the road.
V11 defogger: Turn on HVAC. Swipe up. Look at the screen (sometimes I get the full menu; sometimes I get the short menu). Decision point:
- If the small menu shows up press the mini defogger icon.
- If the large menu shows up press the big defogger icon.
Look back at the road. Takes about 500ms to refocus attention. Total distraction - at least one second (incl. the need to make a decision). Functional benefit: negative. Aesthetically: debatable.
V10 seat warmer: Not looking. Touch the icon. Full attention to the road.
V11 seat warmer. Turn on the HVAC. Swipe up. Look at the screen (sometimes I get the full menu; sometimes I get the short menu). Decision point:
- If the small menu shows up press the mini seat warmer icon.
- If the large menu shows up press one of the big seat warmer icon (there are two different icons with the same function).
Turn off the HVAC. Look back at the road. Takes about 500ms to refocus attention.
Total distraction: About 2 seconds distraction. Functional benefit: negative. Aesthetically: debatable. In this case I would point out that you have to engage/disengage a totally irrelevant system which also leads to unnecessary wear of the HVAC compressor.
Does increased period of lack of attention to the road lead to more danger? I have not done a study but I would make a wild guess, that is supported by hundreds of studies.
