I want to make a 35 foot nema 6/50 extension cord. I just need confirmation that the below selected cord will SAFELY work.
It is from a website called wire and cable to go. I will purchase appropriate plugs on Amazon.
THANK YOU for any help.
Debbie
Cut to length - sold by the foot. Enter the desired footage in the QTY box.
Minimum 10 ft. to maximum 1000 ft. Please call for longer put ups.
Color:
Black
Applications:
SOOW Flexible Cord applications include portable tools and equipment, portable appliances, small motors and associated machinery
Features:
Excellent resistance to oil and moisture. Good tensile strength, elongation and aging characteristics. High flexibility. Excellent abrasion resistance. Sunlight-resistant. Temperature range: -40ºC to +90ºC
Standards:
MSHA Approved
RoHS Compliant
Construction:
Conductors:
18 through 2 AWG fully annealed stranded bare copper per ASTM B-174
Insulation:
Premium-grade, color-coded 90ºC EPDM.
Specifications*:
Number of Conductors: 3
Conductor Strand: 101/26
Insulation Thickness: 0.050 inches
Outside Diameter: 0.790 inches
Weight: 0.510 lbs per ft
Current Amps: 55
Color Code:
3 Conductors – Black, White, Green
*Data provided on this page is subject to change based on different manufacturers variances.
Debbie
Color:
Black
Applications:
Features:
Standards:
MSHA Approved
RoHS Compliant
Construction:
Conductors:
Insulation:
Specifications*:
Current Amps: 55
Color Code:
