Very cool extension cord to have in case
Discussion in 'Model S: Battery & Charging' started by Firewired, Jan 16, 2016.
  1. Firewired
    Firewired Member
    San Antonio
    I couldn't find this info already posted when I searched for it. So forgive me if it has already been mentioned.
    I recently got back from a road trip out of Supercharger range which was kind of painful. At the condo I stayed at I considered it would be possible to have charged via the dryer outlet if i had the adapter and an extension chord. I wanted to order both the Tesla Chademo adapter, an 14-50 extension chord and a 14-30 adapter for dryers. Well lo and behold EVSE Adapters.com has a universal extension chord that was designed for EV use that will fit both the 14-50 or 14-30 plugs, so need to carry multiple adapters.
    Heavy-duty NEMA 14-50 extension cord for Tesla, 20 ft.
  2. kort677
    kort677 Banned
    florida.
  3. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    FWIW, I've charged places where I needed every inch of the 30' extension cord. A 20' extension cord is a bit short IHMO.
  4. Firewired
    Firewired Member
    San Antonio
    I thought the thing that was so cool about this chord is that it can plug into both a 14-50 and 14-30 plug without need for any adapters.
  5. brkaus
    brkaus Well-Known Member
    Austin, TX
    Be sure to set the current limit properly when plugging into 14-30.
    I believe the only difference is the special extension cord does not have the neutral.
  6. Firewired
    Firewired Member
    San Antonio
    Thanks for the suggestion to limit the power on the 14-30.
    I agree the only difference is the lack of the 4th unused prong. I just thought it was cool to be able to carry one chord that could fit the two different scenarios. I had on my wish list to get the 14-50 extension chord and a 14-30 dryer plug adapter just to have on my next trip, just in case. I was glad to be able to get both scenarios with one chord , and not have to worry about another loose piece of gear, and save the price of the additional adapter.
  7. scaesare
    scaesare Well-Known Member
    NoVA
  8. Cottonwood
    Colorado
    This is a great cord for EV charging, but could fry 120 V appliances in an RV.
    Make sure to label the cord/adapter well, that it is for EV charging use only, and absolutely not for RV use, can be dangerous for RV's.
  9. Zybane
    Zybane Member
    Washington D.C.
    You just get the 30 foot cord off of Amazon and break off the neutral prong. You don't need that.
  10. Rocky_H
    Rocky_H Active Member
    Boise, ID
    I got the 30 foot Camco cord from Amazon, and yes, the one time I needed and used it, I needed every bit of the 30 feet and then some. I had to go partway up a driveway, in the side door of a house, down the stairs to the basement and then across the laundry room. In hindsight, I wish I would have made my own. Eliminating 30 feet of that extra neutral wire inside the cable would have made it a lot lighter and more flexible. The Camco one is a beast. EVSEadapters will respond to custom length requests, so you can probably order that one from them and ask them to make it as a 30 or 40 foot.
  11. jct_4628
    jct_4628 Member
    Wisconsin
    You can pick up 30 foot cords at most hardware stores also. I found one at Menards that was the same price as Amazon and I was able to get it that day.
  12. Newscutter
    Newscutter Member
    Wexford, Pennsylvania, United States
    #12 Newscutter, Jan 19, 2016
  13. Firewired
    Firewired Member
    San Antonio
    Awesome review. Based on suggestions I emailed the site to see if they would make the chord 30". Let you know and for how much. Looks like all three extension chords options at EVSE Adapters, Chord Depot and Camco are 6 AWG wire.
  14. InternetDude
    InternetDude Member
    Yes
    Why the hell cant you spell the word CORD properly?
  15. Firewired
    Firewired Member
    San Antonio
    I can, I think it's my damn Apple iPad spell correct, or too much guitar. Thanks for the feedback. Seems like I struck a chord with you.
  16. InternetDude
    InternetDude Member
    Yes
    Good one! LOL
  17. Newscutter
    Newscutter Member
    Hope that extension quart works well for you.
  18. liuping
    liuping Active Member
    San Diego
    The problem with the Camco cords (I have one), is they are VERY heavy and stiff.
    I think the evseadapters.com version has 1 less wire and is lighter and more flexible.
    Assuming you only need it for EV charging, I'd go with the evseadapters.com cord, just ask for him to make it 30ft.
  19. DCGOO
    DCGOO Active Member
    Indianapolis, IN
    Correct on both counts. The Camco is a true 14-50 extension, containing 3, AWG 6 conductors, plus a ground. The EVSE does not have the neutral conductor, so it is immediately 2/3 the size and weight. But it can only be used to charge your Tesla.
    I thought about removing the neutral from the Camco, but I hesitated, thinking there might be a time I could use it with my RV. So I bought the EVSEadapter cable too. I carry both in my S (along with a couple others I made up).
  20. AWDtsla
    AWDtsla Active Member
    NE
    #20 AWDtsla, Jan 21, 2016
    The guy is wrong. He was pulling basically the same voltage before and after, the mph reading is prone to error from averaging and auxiliary usage, like the heater turning on.
    Also, good reason to build your own. Temco soow 6/3 cable I got is light a flexible, even in cold weather. If I were doing it again, I'd go one more size down, save another few pounds. The UMC cable is tiny compared to this thing, it's overkill.
