ExactlyIt’s been a bit since I last saw this thread. So to summarize so far: this is working on Intel based cars but still having issues on AMD cars?
what is the model number on the plaid tuner again? might try to order it thru the app and see if that works.The sound quality wasnt an issue for me ever. I guess my "clipping" was music cutting in and out.
What happens if you just find a VIN online from a used vehicle listing for example and use that?they're still giving me a hassle through the app.
"if the part is for anything other than a model 3, we will need the vin to that vehicle."
this after i sent them a screenshot from the parts catalog where it clearly says no vin required. madness.
also, hilariously, the radio for the model 3 now costs almost $600.
Tesla customer service is by far the worst. It will prob be the reason that I wont purchase another Tesla. Their #1 excuse is always "we technically are not a dealership"they're still giving me a hassle through the app.
I have all those same problems once in a whie. No idea what causes it but i noticed if you switch to streaming for a bit then back to FM all of it goes back to normal.@ph0ton @PhilCaps since you two are the two who seem to use this the most like i do (and anyone else really who wants to chime in), can you check something for me? my FM radio still works, but i've lost the "stations" list for the most part (where it used to be present almost all the time)...the tab on the FM app that shows you the stations that are available in the area, along with all HD sub-channels. for me, this list seems to have disappeared completely except that occasionally it comes on and shows me only the station i'm listening to, if i leave it on long enough.
wondering if this is something weird going on with just our SXM hack, or just my radio. my reception seems to be fine, i can still get all the stations i previously could at my home...i just don't have that list coming up anymore when driving around. i noticed the other day that it was gone when i tried to listen to the traffic report on KNX, and just did a quick drive around tonight to test it out...sure enough, that screen never showed me anything other than the station i was currently on.
also weird, the little signal strength icon at the bottom right of the FM channel icon keeps bouncing between having signal and then having a line through it. off and on and off and on. constantly.
trying to figure out if this is something that has broken in my setup, or if they borked something in a recent update (would be interesting to hear if any regular model 3 FM radio peeps could chime in, perhaps i'll post this as a question in the main forum after you guys can confirm whether or not you're seeing the same thing).
I haven't observed this behavior. I was reticent at first about using the amplifier on the second antenna because though it would increase the amplitude, it probably does nothing for the signal to noise ratio. I suspected that maybe I might lose channels or data over channels because the amplifier might be just amplifying noise.@ph0ton @PhilCaps since you two are the two who seem to use this the most like i do (and anyone else really who wants to chime in), can you check something for me? my FM radio still works, but i've lost the "stations" list for the most part (where it used to be present almost all the time)...the tab on the FM app that shows you the stations that are available in the area, along with all HD sub-channels. for me, this list seems to have disappeared completely except that occasionally it comes on and shows me only the station i'm listening to, if i leave it on long enough.
Maybe the polarity is reversed on the jumpers?
I am pretty sure one of the leads off the antenna is just for noise filtering (via destructive interference) within the amp. On the other hand the fakra just has one wire for signal (the inner one) while there is a braided wire around it for EMI filtering. You should be able to trace the ground wire and use either aerial for the signal.I thought maybe this was it, but I've tried it both ways with no change. also, it was working fine when I first hooked everything up and then subsequently has stopped (which is why I thought maybe it was an issue with a recent update). the weird thing is that the radio itself still works and is still pulling in stations from far away just as strongly as it was before, just with this new odd behavior.
edit: perhaps I'll try to create a jumper to fakra wire this weekend if I get some time so I can bypass the second amp and see if that changes anything. I have no idea how to install a fakra though, so it would probably entail just getting an existing fakra cable, cutting one end and soldering the three jumpers to it. would that even work?
interestingly enough, I did a service mode software reinstall last night before going to bed, then let it sit overnight (which I suppose is the same as a hard reset)...this morning, it's gone. we'll see for how long, but hopefully that plus covering up that small nick on the wire in the harness will take care of it. I'm not getting my hopes up, though.Yeah definitely not my "clipping". That's bad
