Launch window is Now 7pm EST
Then why does it say "Live in 4 hours"??? The end of the window is coming up in an hour and 20 minutes.I think that time on the feed is bogus. They’re pushing it right to the end of the window at 8:32.![]()
Bad web management???Then why does it say "Live in 4 hours"??? The end of the window is coming up in an hour and 20 minutes.
So reason for scrub is unfavorable high altitude winds?Scrub! Darn it. See you tomorrow. Same time frame.
Yes, quite informative! I recommend reading all of the “green” posts after your get past the Shuttle discussion. Including the one from Tory Bruno from ULA.Informative discussion of how wind shear effects rockets at What factors affect the ability of a rocket to sustain high-altitude wind shear? : spacex
Remember wind shear is not wind speed. It's the difference in wind speed between the top and bottom of the rocket.
What that difference does is turn the rocket. The rocket corrects with an opposing torque by vectoring its engines.
However, in the brief time before this correction is accomplished, the rocket is flying slightly sideways.
Around max-Q, the pressure of the wind on the rocket is very significant. ISTR (someone correct me!) for a Falcon 9 it's around 1 atmosphere, or 14 psi.
A large rocket times a very small angle is a lot of square inches and many tons of additional aerodynamic pressure. Also, there's the torque from the engines that needs to be transmitted along the body of the rocket.
These are additional wonky loads on a rocket structure that's aggressively optimized for weight.
The solution is to either make the rocket stiffer (more weight, boo!), or limit launches to days of low wind shear.
