First, this study seems to be based on generic auto cells, not Tesla's.
No, thats not correct.
Several of the studies I have linked to has used Panasonic NCR18650 (either NCR18650B or PD), thats a Panasonic NCA cell very closely related to the cell that is/was used in Tesla model S. These have the same energy density as The panasonic NCA cells (NCR18650) used in Tesla model S/X. Without specifically getting the hand on Tesla cells, these are as close as we can get to using tesla cells of 18650.
For model 3 and Y the chemistry was initially more or less the same, only the form factor was changed. The later Panasonic 2170L that I have in my M3P also seems to follow the same lines as the earlier 2170.
(I have 35 Panasonic 2170 Tesla cells that I use for own tests. So far, these seem to age about the same as the graphs i have posted about NCA cells.)
As all lithium batteries except some special chemistries not discussed here have about the same behaviour for calendar aging, and all research about NCA chemistry show about the same calendar and cyclic aging it is very probable that The PAnasonic NCR cells Tesla put in their cars also behave the same.
That's not the way that I'm reading it. I'm seeing only an 8% additional decrease over 15 years with battery aging still seeming to be the biggest factor.
The branch standard is that a lithium battery life is said to be down to 20% degradation, after this the degradation becomes more unpredictable and often the degradation curve dives.
The manufacturers spec’s the batteries down to 80% remaining capacity and the researchers mostly test to 80% remaining. In some tests they look at the degradation beyond 80%, and the conclusion in this research is that in general 80% is the end of life.
I just grabbed a picture from a cycle test, its clear that at 80% the curve dives:
Even if Tesla set the warranty at 70% this does not mean that the battery is very fresh at 72%. What it really means is that when you reach the 70% level, the battery has reached the end of life.
If you have lost 8% after 15 years, the battery has a lot more to give, but if you are closing in to 20%, it starts to be close to the end of life.
The two main parts degrading the battery is the SEI layer growing too thick and lithium plating.
If you have reduced these factors the life of the battery will be longer.
That tells me not to worry about it.
You do not need to worry if you can accept a higher degradation.
SoC does not make a significant difference.
That statement is wrong, did you ever hear of the dunning-kruger effect?
It seems like as you continue to use statements like “SOC does not matter”, “these was not Tesla cells” etc but you have no source to back up your statements you are not interrested in learning or a discussion using facts or statements that can be supported by *anything* there we will not get anywhere With continuing this. Its better that you continue to charge to 80 or 90% or what you currently use.
For this thread and the original OP question, I would say that you should provide credible sources to statements you write.
