AAKEE discussed this back earlier in this thread along with some real world examples from his own vehicle.So, how many more miles can I expect to get?
I'd recommend you go back and read that post for more information.
Depending on the situation and how you set your charging schedule, its possible to cut the degradation in more than half. Just having the SOC on the right side of the step for most part of the day cut it in half.So, how many more miles can I expect to get?
Does calendar degradation dominate for the first 5-8 years, or until degradation reaches a certain point? In other words, if you can keep calendar degradation low for the first 8 years, is the battery more likely to still have calendar degradation as the dominant component into years 9 and 10 vs. someone who consistently kept the battery at near 100% SoC?For ”miles” we can look at this graph.
All different cycles use the same DoD (10%) in this graph. Theres quite some difference in battery life if cycling low instead of high.
I went for the low SOC approach from the car was new.
Current battery capacity is about 78.6kWh/ 490 miles.
All 8 other similar cars at the same ODO reading has a lower range and the average is 460-465 km at my mileage.
Full range when new was 507km so my car has lost about 3.3% indicated range.
(Last full charhe was 498km, 1.7%).
If we split it into cyclic aging and calendar aging first.Does calendar degradation dominate for the first 5-8 years, or until degradation reaches a certain point?
My car wit an average cell temp of 13.46C and average SOC (climbing after change of job about one year ago) at sbout 40% will also continue to follow that square root of time. Low Soc and low temp gives quite low rate even the first year.In other words, if you can keep calendar degradation low for the first 8 years, is the battery more likely to still have calendar degradation as the dominant component into years 9 and 10 vs. someone who consistently kept the battery at near 100% SoC?
Absolutely. Its posdible to set the timer so the soc is 20 or 30% when leaving.That chart is interesting. It suggests that I could dramatically improve battery life by charging only to say 20-30% SoC, even though the car will not let me set that as its limit.
In plain text, its not the miles that degrades the battery during the first 5-8 years or so.
All cycles in that chart is Full Cycle Equivalent (FCE). Marked on the X-axis scale.Just to make sure that we are talking apples to apples, what's the definition of a cycle in this chart?
For case #31 is a cycle 0-10%
or is it 0-10% ten times?
I'll tell you what. How about I buy two Teslas and drive them for the same number of miles and put the same number of FCE cycles on both of their batteries, except on one of them, I'll do everything I can to prolong the life of its batteries and on the other, I'll do everything I can to shorten the life of its batteries, according to what I believe shortens or prolongs the life of lithium ion batteries. If there is significantly more degradation on the one whose battery life I am trying to shorten, then you pay me for both Teslas but I remain the legal owner and can do whatever I want with them. Deal?
Are you talking about the reports that ONLY cover 2 years?AAKEE discussed this back earlier in this thread along with some real world examples from his own vehicle.
It's actually not possible in my case because I don't have a consistent schedule.Absolutely. Its posdible to set the timer so the soc is 20 or 30% when leaving.
Sure. I think your climate plays about as big of a role in minimizing degradation as your management of SoC levels though. I don't think someone in a hot climate could hope to duplicate your results even with more careful SoC management. 13.46°C average temperature is really, really low and I would expect the car to use the battery as a heat sink for the cabin air conditioning until it reaches at least 20-30°C (and in some climates you're almost always using the air conditioner). I wouldn't be surprised if the batteries for a vehicle parked in Honolulu for example rarely ever go below 22°C and routinely are allowed to go as high as 30°C before the heat pump starts cooling them down.But I decided to use the charhing tactics that really do not hinder me to fedl free and not to involve in a system that makes it not fun to use the EV.
I charge to 55% as it is below the step, the best compromize between low degradation and freedom.
It would be pissible to reduce degradation much more, but for me it would not come without making an impact on the freedom etc.
I am happy with my low degradation, it follows ”my plan” very nice so…
Oki, I have no real solution for that, I guess. If you know the next days timings, you could adjust the starting time of the charge each evening?It's actually not possible in my case because I don't have a consistent schedule.
And there's a big difference between the battery in my PHEV and the battery in my Tesla. If I ever find myself short on battery power in the PHEV, I just have to burn a little bit more gas. There have been times when I had to drive the PHEV unexpectedly and I had the battery basically sitting at empty, but it's not a big deal because I have never had to alter my schedule because of it. But still, 30% SoC in the Tesla covers almost 100 miles of driving, which is more than enough for any unexpected drives in daily use. Would be extremely helpful if they allowed you to set limits as low as 20%.
Im not sure for who this message is?The one thing you are forgetting is the need for cells to balance. And to balance the charge needs to be above 85% and 90% is better. Below 80% there is little opportunity to balance and your range is then limited to the weakest cell. It can be recovers but that normally takes a few weeks. If you fully charge for trips say 3-4 times a year you should be OK. But if this is an around town car you will notably degrade the range.
The researchers most often do the calendar aging tests for one of two years. There has been a lot of reasearch about the calendar aging, and as it seems it continues to follow the square root of time.Are you talking about the reports that ONLY cover 2 years?
This is not a research study, nor is it only 8 cars. It was 8 cars that had charging data at the same ODO. There is at least 35 or so M3P 2021 using teslafi sending data. It was 8, after the evenings 100% charge that showed my range 495km, there is only 5 cars today with charging data at that ODO Reading.Different degradation factors from total lifetime. And a study size of 8 vehicles, well, says nothing to me.
I'm asking for a simple answer to the question, for which 95% of people reading this want. What's the difference in lifespan. Either in years or miles.
I learned the basics of lithium batteries more than ten years ago. I did find the advices conflicting, sometimes strange, and also found that most peoples lithoum batteries died when they followed the ‘strange’ advice.Is there such a thing as Tesla Battery Psychosis? But thats probably for a Psychology Forum. At what charge parameters does a Tesla driver loose his/her mind trying to keep "Perfect" charge, "Perfect" battery life and actually use the car for something other than up and down the driveway?
Many of the answers early in this thread is completely wrong. We know this from science.what charge parameters does a Tesla driver loose his/her mind trying to keep
First, this study seems to be based on generic auto cells, not Tesla's.The life doubles.
As it already is in pair or about in pair whit the cars life, we get less range loss and a better re-use of the battery afterwards.
Definitely possible, although not sure if it's worth the effort to do it. I certainly do this with my PHEV because I'm adjusting the schedule every time I pull into the garage and I generally don't plug in until the night before I am going to drive it next. But I don't have the patience to micromanage the Tesla like this. Most I would do is not plug in until the day before I am going to drive it but that runs a risk of just outright forgetting to charge it. So even though it does charge by the next morning, it is only charging to 50%.Oki, I have no real solution for that, I guess. If you know the next days timings, you could adjust the starting time of the charge each evening?
What does the heat pump do when it's 46°C outside? That happened once here and it was awful, but I can't really see what my heat pump is doing. The AC in my house was running (although not continuously) between midnight and 6 am at that time and the garage felt like a sauna in the afternoons and evenings. It was basically a 3-5 days of high temperatures > 40°C.If / when we need aircondition, the ambient is hot here also, otherwise we wouldnt need AC. I have data that my car is most efficient between 20-25C, so not much power for AC could be needed before that. There will be some times when the AC could shuffle heat into the battery, but it is not that often.
I havent seen the heat pump cool the battery. I do not think Tesla does? Cabin overheat protection cools the cabin I guess.
Hot summer days with 30C and driving set the cell temp well above 30C, and my car has not cooled the battery when not driving (not meaning the afterrun of fans etc shortly after a drive).
Let it float starting at a level you are comfortable with charging, and dropping to ~20-25%. If you need to drive more urgently, stop at a nearby fast charger to increase SOC to what is needed for your trip. I charge to 80% because that is below the Tesla designated trip, and then recharge when needed. I wouldn't overthink it. You'll spend more time worrying about it than its worth.Based on what I've read, I'm sold on keeping my vehicle charged to its lowest SoC that suits my driving needs for a daily basis is what works best for me. For my needs, I'm easily able to stay at 50% for a target charge level and have more than enough capacity for my driving needs.
My question is if I make multiple daily trips, is it better to constantly plug in after each trip backup to 50%? Or to just charge once per day and let my overall daily SoC remain lower?
In other words, assuming that my charge level is set to 50%, is it better to do 3-4 x 5% charges (i.e. 45% back up to 50%)? Or to do one charge overnight of 15-20% for the day? The prior keeps my charging cycle smaller but the latter keeps my battery at a lower SoC as an average?
I realize that I may be splitting hairs here in doing what I can to maintain battery health, but I don't feel it's an hassle for me at all for me to do it whatever way is best for battery longevity. I typically just make in town trips and I work from home so am easily able to plug in between trips (with the only inconvenience being to reach over and plug in the charging cable that's right next to where my car is parked).
