Feature Request: Slowmode
Discussion in 'Model S' started by trond.strom, Jul 28, 2015.
Tags:
  1. trond.strom
    trond.strom Member
    Norway
    When parking and or driving where there is little room for error I would have loved a "Slow Mode" or prescision mode.
    when enabled car tops out at 10kph and a floored pedal would maybe be 5-10kw power. I believe this would make handling the car through narrow passways and sharp turns a lot easier?
    any thoughts?
  2. JER
    JER Member
    Bristol, UK
    I've driven a P85+ and an 85 with the 6.2 firmware. In both cases, the modulation of the Model S accelerator pedal was, in my estimation, fantastic for low-speed precision already. I had no trouble at all making the car move as slowly as I wanted. Creep was off.
    The feature is not needed IMO.
  3. commasign
    commasign TeslaAdviceBlog.com
    Davis, CA
    I leave creep mode on and use brake pedal to modulate speed during parking and other low speed maneuvers.
  4. trond.strom
    trond.strom Member
    Norway
    maybe its diffrent with my 85D especially reversing slowly seems to be very sensitive
  5. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    I have an 85D and for me, I would not need this at all. I have creep off, and using only the accelerator pedal, I can control the car with probably 5x the precision with which I can control an ICE. When I drive into my garage, I can position the car within 1/4" of where I want it, and can approach that point at a 1/2" per second speed quite easily.
    This has nothing to do with my skill (which is average most of the time, maybe slightly better on a good day) -- it's the nature of the electric drive.
  6. RDoc
    RDoc S85D
    Boston North Shore
    Where I see a bit of a problem is reversing into my garage and getting over the 1/2" or so lip at the edge. I'd like a more gradual power increase there, some way to creep over it rather than jump. Otherwise, it's great.
  7. ThreadAbort
    ThreadAbort Member
    Chesapeake, VA
    Imagine if you forgot to put it in slow mode and stomped it.
  8. caps04
    caps04 Member
    NJ USA
    This may be a safety issue. Imagine being in slow mode and you see an out of control car skidding straight at you. And reading some comments above, I just realized that my 85D is super accurate in slow speeds: I always park my car almost within an inch of where I want, every single time. I could never do it with my other gas car.
  9. sorka
    sorka Well-Known Member
    Merced, CA
    I leave creep mode off. I often give demos how easy it is to move millimeter by millimeter with absolute precision. There is nothing else like it. It makes parallel parking when you your trying to get real close to the curb without hitting really easy.
  10. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    Generally speaking, I have no problem as my S85 gives me precise enough control through modulation of the go-pedal. That said, I realize not everyone may have the same precise ability to control the go-pedal. Case in point, my right foot has been in a boot for a few weeks now while I heal. As such, I have found I cannot "feel" the go-pedal anymore to have precise control. I have a couple times now turned on creep to help with low speed parking maneuvers.
  11. ken830
    ken830 Model S 85, Model 3 Performance
    San Carlos, CA
    This sounds like a joke? Seriously, the electric drivetrain is amazing at low-speeds. Trying to slowly move up a ramp, over a speed bump, or simply parking in tight spaces is way more controlled in the Model S compared to any gasoline engine-powered car with a manual or automatic transmission.
  12. eloder
    eloder Active Member
    Ohio, USA
    I don't own a Tesla, but how would that differ from leaving creep mode on?
    My own EV is incredibly precise for low-speed and I don't need to turn on Eco Mode (basically does what you'd describe in a Slow Mode) to reach that precision.
  13. Dwdnjck
    Dwdnjck Member
    Low speed control of model S in phenomenal. It's much better than any ICE.
  14. sorka
    Merced, CA
    In creep mode, power is constantly applied which means you have to use friction brakes to modulate the power to the wheels.
    The reason this matter boils down to physics. The coefficient of friction between two objects is almost always more for static friction than it is for kinetic friction. This means that the brake pedal force needed to keep a stopped car from resisting the force to move it is less than if the car is already moving i.e. the force to keep the drums or rotors moving against the brake pads is less if the drums or rotors are already locked. Once the brake force is lifted enough to allow the force from the motivating device to overcome the brake force, the drums or rotors turn, but to stop them, you have to apply more force than it took for the release.
    What this means is that the point at which the car stops or goes has a large overlap in the pedal points that stop the car or let it go. It means you can't hold the brake pedal at one point between stop and go because those points overlap. The result is when you're trying to inch along millimeter by millimeter, every time the car stops, you have to lift the brake pedal a bunch just to inch forward again and the sudden *change* in the co-efficient of friction results in the car lurching forward no matter how slowly you lift up.
  15. sorka
    Merced, CA
    BTW, if you a car that has creep and it can't be turned off, you'll realize just how much more precise the MS is with it's creep turned off when you finally try it.
  16. trond.strom
    trond.strom Member
    Norway
    Looking at the answers it seems all I need is a little more practice with the car at low speed.
  17. eloder
    Ohio, USA
    I'll have to look forward to it.
    I actually wouldn't be surprised if my Leaf already does power modulation (not related to braking) with the creep by using the brake pedal. My car (and I imagine a lot of other EVs out there) apply 0 power, then regen braking well before taking my foot fully off the fun pedal, and I've been able to sustain a rate of speed well under the normal creep threshold with light brake pressure--seems like it'd make sense for EV engineers to let the brake pedal control actual motor power and acceleration at very low speeds just like the fun pedal controls regen braking.
    I'll have to see when the Model 3 comes out how the two differ, as my Leaf with creep is already incredibly precise at low speed control.
  18. techmaven
    techmaven Active Member
  19. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    Car is already precise enough. I can move forward or reverse in fractions of inches if I need to. What I don't need is a ton of unnecessary options on my car's settings screen.
