Interesting data point. Upgrade 4.5 to 5.8. Before upgrade range showed 352 km. After upgrade range showed 345.
On the other hand, the screen that shows/controls % charged indicated the car was lower than my set point.
Yeah, apparently adjustments to how range is calculated were introduced with 5.6, which are obviously still present in 5.8.
- - - Updated - - -
Ah! Yes, that makes much more sense now. I was mostly talking about range at highway speeds. Interesting, that's a good point, I wonder if it won't handle as well at higher speeds now. Also, I'm going out today on the freeway and I'll certainly do some tests (especially with leaving the car at a higher setting to see if it auto-adjusts).Sorry, I wasn't clear enough. I only got the upgrade notice yesterday morning, I didn't install it as it was going to be a long driving day (which is why I said I hadn't checked the behaviour today). My expectation is that had I installed it, it wouldn't have mattered much. Note my average is 257 Wh/mile over 13,400 miles, so YMMV. I suspect it makes more difference to handling than it does to range unless you're going 70+ mph.
