You got the new Battery Day breakthrough!
WTF?
I spent considerable time fixing my own panel gaps after Tesla refused. This was under the cowling in the frunk.
So really no way to check this without removing the frunk insert?
I will bet that the shorts would love that picture. That should be reported to the NTSB Is that an item that gets very hot? If it is that is dangerous..
It is one of the coolant to refrigerant heat exchangers. It will get hot (battery pack temp plus some delta), but not hot hot.I’ve seen the green plastic in pictures of other cars, so I think if that assembly generated/dissipated significant amounts of heat it would melt the green plastic. Not really concerned about it from a safety perspective but would love to know if I should be.
well the only thing that matters....did you fix/correct the gaps? =]All very helpful, thank you.
Is it a big deal that Tesla used faux wood trim during assembly of my vehicle? No. Is it funny? Yes, yes it is!
I’d probably think it was funnier had I not had to spend 10 + hours disassembling and reassembling my vehicle to correct the gaps and alignment.
You found the LCC. What's the big deal?
Mine has exactly the same thing. Serial number 23XXX
