Found this little gem on my $55K Model Y
Discussion in 'Model Y' started by Brown1428, Sep 8, 2020.
  1. rxlawdude
    rxlawdude Active Member
    Orange County, CA
    Again, imply the problem exists for all without evidence.
  2. electricar
    electricar Member
    NotCal
    We should each get a Tesla R&D Team ball cap when we take delivery of our cars
  3. rxlawdude
    Orange County, CA
    They used to give you a ball cap when taking delivery. Though it was the "Tesla Racing Team," not R&D. :cool:
  4. CertLive
    CertLive Member
    United Kindom
    • Funny x 2
  5. rxlawdude
    Orange County, CA
    "First hand" accounts do not implicate the majority of Teslas, unless you have actual statistics for all Teslas. Do you?
    Also, I crack up at that OP you linked. Some people think a dust nib in the paint is reason to whine. These people need a hobby.
  6. CertLive
    CertLive Member
    United Kindom
    That OP of that material is me and as so many people fail to do is actually read things in full. Faults in all glass panels is not a dust nib etc etc. No it was a large list. So I would assume its possible you have not read the full new from the OP here too and the large response of confirmed cases. Seeing as this wonderful website represents a sizeable but not the majority of owners then you would be worried at the frequency of day one issues to be quite high that appear here. Dust nib is still a reason to whine and get fixed though.
  7. Techie-HEX
    Techie-HEX Member
    PA
    My guess is parts shortage during COVID. You can't hold up the line for a simple plastic part!
  8. cucubits
    cucubits Active Member
    TX
    This shouldn't be an excuse. If they took a shortcut here, who knows what other more critical part is put together the same way.
    • Disagree x 1
  9. Quasar255
    Quasar255 Member
    San Francisco
    WdF argument there.
    Covid also reduced my income a bit. Can I buy it $2000 cheaper.
  10. bhzmark
    bhzmark Active Member
    Sounds exactly right below. Anyone who continues to complain about this without dealing with this much more plausible explanation is just dealing with their fantasy to support their complaint rather than the rational and best-evidence-so-far based explanation of this. Which one are you?
    This guy below, laughably confessing to be a terrible engineer, clearly dealing in the fantasy department.
    And this one below just trafficking in insults rather than dealing with the facts and evidence.
    • Disagree x 1
  11. Daniel in SD
    Daniel in SD Well-Known Member
    San Diego
    I agree with the explanation but I don't think it's irrational to be worried about this fix. That's probably a very expensive assembly. I predict that Tesla will change the design to eliminate the strap. When that happens I suppose someone could argue that they only redesigned it to eliminate the labor of the putting on the strap but I suspect that it's a real reliability issue. Only time will tell!
  12. mongo
    mongo Well-Known Member
    Michigan
    Ideally, the nylon cross piece would have a fastener or two into the LCC, which would have to be tabs that bracket the ports like the refrigerant side. I'm thinking the strap is not such a bad approach. The concern would be if the corner material is operating at yield or not. The amount of additional force due to differential acceleration should be near zero. If not at yeild, it will kerp things tight. If the strap and/ or nylon brace is set up in a spring configuration, even if the material compreses or ages, the ports will stay sealed.
  13. mark95476
    mark95476 Member
    Bay Area CA
    Great post. Finally, some real info and meaningful analysis instead of speculation and boring chatter.
    Some things to consider:
    1) There are some earlier builds with softer material that seemed to have crushed the corner protection. Were there any leaks?
    2) CoryS from Munro said the steel band on one of their newer test vehicles cracked the nylon brace. Were there any leaks?
    3) I think the first MY service schedule for the AC system is to refresh the desiccant after 4 years. When do they check the AC system seals for leaks? ...Never?
    Maybe someone with a reliability hat on saw that and said something like "this looks great and all, but let's make sure nothing ever goes wrong. Here's a mostly non-invasive back-up that will probably never be needed." A Tesla bean counter didn't come in tabulate the price of the steel band, various corners, tape, labor,... etc... and say "nope" and over-ride engineering.
    Agreed. That nylon bracing would be the obvious weak link, if this was structural. Four bolts should be plenty strong to keep the LCC in place.
    Agreed. My opinion: The brace you highlighted keeps things square/flush and there's everything behind (fluid reservoir...etc...) that should keep the two rectangular ports from getting distorted or pushed away from the manifold.
    Those bright red seals are there to couple the nylon to the metal and take-up any movement or expansion. I don't think it make sense to deform the nylon (like an interference fit) with the red seals. You'll crush and distort the seals.
  14. Daniel in SD
    San Diego
    Maybe. The other obvious concern with this fix is the number of variations (fake wood, at least two different types of plastic L pieces, sometimes two plastic L's, sometimes one, and sometimes none). The strap itself looks like it's installed by hand. Is there a tool that measures the tension? My experience with AC systems is that it's best if the last the life life of the car, once they fail they seem to be difficult to fix long term.
    Personally, if I totaled my Model 3 today I would not buy a Model Y until this part is revised. (I also wouldn't accept a vehicle that needed any rework at delivery or in the first 7 days, as it sounds like cars are being sold more "as-is" now.)
  15. mark95476
    mark95476 Member
    Bay Area CA
    Yes, it's all to obvious concern trolling. Times are tough for the Tesla trolls and FUDsters and they'll left to nitpick inconsequential fluff.
    If Tesla are taking note: Tesla should include more of these "Easter Eggs" to get the trolls worked-up and frothing at the mouth. It's amusing watching them be so pathetic. ;)
    • Disagree x 2
  16. asa8080
    asa8080 Member
    Texas
    Internet joke which seems to be real - do not trust users with numbers in name (because many of them trolls/bots)
    Just to think about - that "issue" was found quite a time ago, no service bulletin or recall for that - maybe it's do a nothingburger...?
  17. Daniel in SD
    San Diego
    Why would there be a recall? It's not a safety issue even if it fails.
    If this does turn out to be a reliability issue then there probably won't be a TSB until there is a fix that doesn't involve replacing the whole assembly.
  18. asa8080
    asa8080 Member
    Texas
    Recalls happened for issues not even related to safety.
    I had a CR-V with recall for possible rust on license plate holder and Nissan for other minor issue.
    My point was with BIG amount of Tesla haters (equal or maybe exceed of fanboy camp :) ) if that would be a real issue, that would be addressed in some way. If such "issue" would happened with GM Cruise or Nissan Sentra, nobody would care imo :)
    • Disagree x 1
  19. CertLive
    CertLive Member
    United Kindom
    I just wondered that mask you have on in the picture was that a bulletin fix for the model 3 AC smell issue I had? If only I had one under my seat... but yes true whats the worst that could happen it drops off?
  20. Quasar255
    Quasar255 Member
    San Francisco
    #280 Quasar255, Sep 14, 2020
    I think it’s bit extreme to call Tesla haters to those who point out some bad quality issue.
    How much GM Cruise and Nissan Sentra sell for, compared to MY?
    ....and, not sure about GM cruise, but Nissan will never ship off from production line with this clooge fix.
