Trying to decide if it is worth going from standard HVAC system to heat pump. I'm based in Northern California where temps are mild. Winter mornings hit in low 30s and summer temps hit highs in high 90s low 100s.
With that said, I just got PTO on a a 12kW system with 2 Powerwalls in October 9, 2022. I oversized the system in hopes to be able to cover future usage such as adding another EV. Since PTO on October 9, here has been my monthly electricity:
- October: -487.86 kWh
- November: -530.65 kWh
- December: -18.32kWh
- January: 78.69kWh (usage through January 14)
In total, currently have a -958.14kWh credit.
As you know, California has been storming the majority of December/January and likely explains the low numbers.
I've seen a significant uptick in gas usage to run the furnace in the mornings and fireplace at night.
- October: 26 therms
- November: 64 therms
- December: 110 therms
- January: 26 therms (usage through January 14)
PG&E gas prices seem to be out of control with it being $2.78 - $2.91/therm.
With that behind us, few questions:
- Does it make sense to convert to a heat pump system for California?
- What should be the expected increase in kWh consumption? Based on this, will I still have "excess credit" for future additions like EV.
- Are heat pump systems effective? Meaning, is it sufficient to heat and cool the house to temperatures such as 70 for heat and 65 for cooling?
