Gizmotoy
Rick, my question was whether the camera bracket (which Gizmotoy figured out how to remove) or a 3D printer replacement is needed if the camera will be mounted to the Tesla supplied front license plate holder using the mount that you are developing. My original posting of this question may not have been clear.
I don't have the camera yet (should get it on Wed when I take the car in for its 1 year checkup). You mentioned reinstalling the four long screws. Would we need to install spacers to make up for the lost thickness of the original camera bracket, or get shorter screws, or is this not necessary? Thanks.
artsci can chime in here, but from the warnings in the instruction manual, you are told not to modify the metal camera bracket if you're going to be doing their license plate option. Presumably the camera uses the existing screw holes on the bracket wings to attached to their license plate mount. So you won't need to remove the metal bracket or modify it in any way. Here I've created some confusion discussing a hypothetical alternative, which I apologize for. You won't need to worry about any of the things mentioned in my posts for your installation method.
