Any more info?Hi I have never had problem with this before but recently the front windscreen on my model Y keeps steaming up and it takes ages to clear.
Any ideas?
Thanks
It’s good to give the car a 10 minute warm up via the app before setting off… not had steamed windows so far. I leave the hvac on auto …Hi I have never had problem with this before but recently the front windscreen on my model Y keeps steaming up and it takes ages to clear.
Any ideas?
Thanks
Of course even auto has three manual fan settings these days high/medium/low . Unless you are hypermiling, and particularly in cold weather, probably need to leave that on high so auto is not constrained. I imagine the low setting would slow down screen demisting.It’s good to give the car a 10 minute warm up via the app before setting off… not had steamed windows so far. I leave the hvac on auto …
I noticed other cars parked at same location were totally misted up
What model and age do you have?For me the de-fogging is no good at all. Even on maximum de-fogging it takes at least 4 minutes to mostly clear the windscreen.
On our Leaf pressing the windscreen demise button put the fan on maximum, AC and heater on and clears the screen in 3 to 4 seconds.
I have checked to see if the air intake is clear and have had the cabin filters replaced too. Anything else I should check?
Tesla automatically puts the recirc on when AC is switched on (automatically when you defog or demist). This again makes the misting up worse. I normally switch off the recirc and this helps to demist quickly as the cold air doesn’t recirculate.For me the de-fogging is no good at all. Even on maximum de-fogging it takes at least 4 minutes to mostly clear the windscreen.
