I occasionally get a message about a pending lane change and the comment "use turn signal to cancel" or "tap to cancel". How is it expecting me to manipulate the turn signal if I were to want to cancel? Signal the opposite direction?
More often I end up at a four way stop sign intersection where the car has the right of way, but it seems to creep forward, almost going, then stops as if thinking about it or waiting to see what the other cars are going to do. I have tried to tap the accelerator to make it move, but a tiny tap does not seem to do anything. Today I gave it a harder press, almost like I was driving myself and it moved out of the intersection and did not disengage FSDb.
Is there any guideline for how much pressing on the accelerator should be done to give it a "nudge" or "hit" to move along?
As many have said, FSDb waits too long before putting on the turn signal. It seems to be possible to manually activate the turn signal before FSDb does. Any thoughts on that?
Thanks.
Thanks.
