Most likely, it will not be detectedDo you trust a handful of sensors to detect a tiny obstacle?
Is there a chance that the sensor won't detect this bracket? Just got the 2023 MX, not sure if I want to risk it
First test that the door opening to "low" works. If so, set the doors to always open "low" at taht location.Most likely, it will not be detected
Even if you sort it out, the real concern is your other family members, who may think it is ok, but not be cognizant of the sequence of actions (one kid opens the garage door, another kid opens the falcon door...)
You can set it to open low at home.I had a close call a couple of months ago... Was watching TV with the Model X key fob in my pocket (We are about 60 feet from our separate free-standing three car garage) and suddenly the cell phone indicated there was motion in the garage on our garage cam. There should not be any activity in the garage with the door closed and locked! I jumped up and triggered the garage door opener and walked outside to see what was going on.... And opening the garage door just missed the FWD which had been deployed when the key fob pressed against something in my pocket. The garage cam had picked up the door opening in the garage. If the door had opened all of the way, it could have been sheared off by the garage door opening overhead.
I wish there was some way to prevent the FWD from opening while in my garage. Now I never sit with the key fob in my pocket,, it is always in a jacket pocket hanging up in the closet, away from the car.
Thanks, how do you set it to open low at home?
If indoors, it should open low by default. When you force it to open high, then it saves it to always open high at that location. Just click the little X next to that message.Thanks, how do you set it to open low at home?
So go in your garage, open the door and you’ll see the message about always opening high. Click the X.
