I've found that not very effective a lot of the time, because when I release the button, the vast majority of the time, the port instantly locks back onto the adapter, and you don't have any chance to pull them out together. The only way I have found that consistently works is to keep holding the button. That continues to keep the charge port unlocked. With your other hand, grab the adapter, and then you can pull them out together while you are holding the button down. See this video:When you push the J1772 button the port will unlock if the car is unlocked. Then let go of the button and pull out the adapter and J1772 handle together in one motion. The adapter can be removed from the J1772 handle after that, or just left attached.
