Should I be concerned? I had to remove and put back my wall connector (took off in the morning and put back at night) and my voltage is quite a bit lower than it was before I reinstalled everything.
At 48 amps before I was at 240-242v, now I'm at 237-239, 24 amps was 245v before now I'm at 241.
On the wall connector IP its showing l1 and l2 fluctuating between 116-117 for a total of 233v between l1 and l2, before it was showing 117-119 for a total of 236 or so.
Did I botch the install a tiny bit somehow or chock it to my provider dropping voltage due to the cold? Wires are routed nearly identical to first install, 25ft romex 6/3 wiring.
