Hard to tell from the pics how many Volts were there...110 or 220? :wink:
Ouch, murdered that joke.If they want to stay Current they should have had some AMPeras too.
If they had 240 Volts there, they ought to have like 30 AMPeras or so.
GM reports customers searching online for fuel-efficient transportation often begin looking at the Volt, then cross-shop the Cruze.
“Since April, nearly 200,000 visitors searching for information on the Chevrolet Volt also searched for information on the Cruze,” GM said.
In fact, Web traffic data from both Chevy.com and Edmunds.com show the Cruze is the most cross-shopped vehicle to the Volt, GM said, adding the Cruze has been the number-one selling compact in the U.S. for the past couple of months.
Nor are some Chevy dealers altogether unhappy about this. We at GM-Volt have been personally told by a Chevy dealer the Volt was overpriced, as he attempted to switch us to the Cruze. We have heard several similar reports besides.
Perhaps GM’s disclosure is an attempt also at “transparency” on Chevrolet’s behalf, as the company openly says the Volt is still a magnet leading to the Cruze.
“As far as image goes … the Volt is huge because it’s also helping sell the Cruze,” said Inder Dosanjh, a Chevrolet dealer in Dublin, Calif. who was quoted by Chevrolet in the same press release.
Yeah, there are two Voltec EVSEs right in front of the GM advanced tech research center (next to Fry's electronics).
They are clearly marked for GM use only.
Also, those Voltecs might only be 16A.
If you are in that area, there are a couple of 'public' ChargePoints at the CreekSide Inn a couple of blocks away.
DonC said:...Here is why you need one charger per spot and why sharing chargers isn't desirable. First, for security purposes, if you unplug the Volt it sets off the security alarm and I get sent an email alert...
Now the reason the Volt doesn't like being unplugged, is that, unlike your Leaf, the Volt doesn't charge and then shut down. It has a thermal management system that constantly uses plug in power to keep the battery at the desired temperature and/or to precondition the car. That's why your Leaf essentially goes dead after a charge but the Volt shows a blinking green light -- it's blinking because it may still be using grid power even after the battery has been charged. This leads to the second reason why I don't want you to pull the plug on my Volt: on a day like today you'd be degrading my battery...
A Leaf doesn't do that as you have no "fallback plan" when your battery runs out, but a Volt engineer can decide "we would rather have you burn some extra gas to help the battery pack last longer since we have a long battery warantee to consider."...
Those proud Volt owners that are doing 99 percent of their driving in full electric mode are doing more damage to their battery than a Leaf or Roadster owner.
Haven't heard it for a while but one of the downsides to the Volt hybrid is that the battery gets fully charged and discharged many more times than a larger range full electric traveling the same amount of all electric miles per year.
The Volt's battery management system when not charging may be trying to coddle that battery like the Roadster does but the owner above really needs it much more for sustained battery life.
Is that "EV2 Electric" plate on the Volt something that a dealer put on there?
