What is so bad about the way the car drives when it is really cold, exactly?
The pumps ramp up as the motor stators heat, it takes maybe 30-60 seconds to hit full speed. But the buzzing starts immediately and it’s fairly noticeable.
It heats until there’s maybe 3 regen dots most of the time.
I have noticed the spool up of that pump (but I don’t hear the associated pre-heat motor noise at the same time). However, when I am at a fairly high SoC, the front motor sounds a bit louder anyway (presumably due to the higher voltage...but it definitely isn’t preheating for this specific motor noise; it is a bit different noise).
Generally I do notice this louder pump sound when I am 1) at relatively high SoC and 2) I ask a fair amount out of the car from the beginning. Generally I feel if I don’t give it the beans, it won’t tend to spool up the pump.
I’ll have to pay closer attention to exactly when I hear this noise, in future. Of course, I never preheat my car and I would not even know how to tell from the app that the battery is being pre-heated (never paid attention in SD of course). When driving, I’m reasonably sure I could reliably tell if the motor is being used to heat the pack, as I am fairly familiar with that noise, from some of my more recent Supercharging events.
The pump spool-up is something related, but different AFAIK. Maybe it only spools up the pump if there is actually excess heat that can be used to warm the pack (that would make sense)?
Again, I have a hard time believing it is energy efficient to warm the pack. It makes sense if the car is plugged in of course, but I can’t imagine it’s a net win otherwise.
I could imagine they might make efforts to shunt waste heat to the battery at relatively high SoC, if there is limited regen. That results in pump spooling. But in my modest temps, it doesn’t seem that it is cold enough to require actual supplemental heat by running the motors non-optimally to generate heat (and again, I’m not convinced it is beneficial to do so unless the car detects it is being driven aggressively).
It seems like a complicated problem to determine the optimal course of action, and I would not be surprised if the behavior is dependent on driver demands on the vehicle.
