We recently took a trip up to the NEC and just our luck we encountered gritters on the motorway both on the way up and back down again. I appreciate there is a need to grit to prevent the roads from freezing up, but how on Earth are you meant to deal with them on the motorway? As you’re approaching you can already tell the gritters are out as vehicles kick up a load of the grit. Then when you catch up with them, how on Earth are you meant to get past them without being pebble-dashed? Both times as I tried to nip past them it sounded horrific as the grit was flung at the car.
As it’s sunny, today, I’ve been out to have a look at the car and our windscreen is absolutely covered in tiny chips. There’s a couple of slightly bigger ones, however fortunately they’re still relatively small and not directly in front of the driver. I don’t know whether all these tiny chips were caused this weekend, but certainly our windscreen is absolutely pock-marked. I don’t recall previous cars being like this, but then I don’t think I’ve encountered as many gritters, in the past.
The car is ceramic coated, but clearly hurling rocks at the car is somewhat above the design spec. Any ideas or thoughts on this? Are your windscreens covered in impact craters? Is there some special method to getting past a gritter without looking like you’ve been in the wars?
Edit - Pah, messed up the title. That should’ve been = Ouch!
