*Most* portable generators don't. The Honda EU20i is very portable and will produce cleaner power than you get from the grid. Hz output is not tied to engine speed at all. The generator output is rectified and then fed to an inverter which makes perfect 60Hz (or 50Hz in Europe) sine wave. My EU65iS also does this, but it's not what you'll call portable. Movable, maybe...
The generators that are coupled with inverters typically produce a much better wave form.
So after I washed my Roadster this afternoon and pulled it into the garage I spied my Honda EU2000i generator sitting there (used to run my motorcycle tire warmers at the track and in case of an earthquake/power outage). I remembered this thread so thought I'd take a crack at it.Many generator sets are going to need to "spoof" the GCFI circuit. Many of us have done this by using a resistor across the load to ground/neutral.
With a quality generator, like any of the Honda / Yamaha ones, that can hold the correct frequency / voltage / amps, it should work.
Now, I have cut off the GFCI from the Tesla 120V cord so it would work in public chargers (this was before I got hsharp's J1772 adapter). But the car charged fine at 12A reporting 123V. Generator was running just fine and not even at full throttle. Pics attached.
> Many generator sets are going to need to "spoof" the GCFI circuit. Many of us have done this by using a resistor across the load to ground/neutral.[TonyWilliams]
That would be two equal resistors from each leg to ground? Details (or link) please.
Excellent! I have the same generator and was planning on trying it out on my dad's Model S when it gets here (he's Sig 417) and report back. I likely still will, just to make sure that it works fine on Model S as well. I would think that, if it works on Roadster, it'll work on Model S.
Wow. Your dad must be a lot more generous with his car than I would be. I think if I caught my son doing electrical experiments on my new Model S, I would be absent from these forums for from 10 to life.![]()
IIRC Model S can last a year at 50% SOC. I don't think a few weeks will matter.Just curious...
Has Tesla -- or any EV manufacturer for that matter -- said anything regarding extended power outage (like if it lasts 3 weeks)? I'm curious after the bricking stories a bit back.
Noted, but I was specifically curious about the folks that got delivery just before Sandy and hadn't charged up yet.IIRC Model S can last a year at 50% SOC. I don't think a few weeks will matter.
Even at the 1% SoC loss per day that some owners are reporting?
