MobileClimate
Im curious in how much gear lash play you have in that new front drive unit ..I have a a lot of back and forth play in the front left axle ..2020 MX LR.. or maybe when they put your front motor in they got the clevis front motor mount lined up correctly..it says in the buelltin that the washer could be in the wrong position..i noticed that mine is not lined up correctlyYou may be correct I was the guy that got the motor replacement. Was in the shop for 70 days Then another 70 days for high voltage battery replacement. I put 5000 miles on the car and it seems to drive better than it did when it was new. If it’s an issue on the motor causing the problem Tesla has a lot more liability
