A further update on this (yesterday I did NOT make a note if the car was locked or not).
I did not install the foot sensor (for reasons I had previously posted). I would assume it would behave the same way as above when the car is locked/unlocked but don't quote me on that.
- When in "D" and the car is locked, I CANNOT open the trunk by physically pressing the button on the lid.
- When in "D" and the car is unlocked, I can open the trunk by physically pressing the button, however, a warning pops up on the screen saying that the trunk is opened.
Personally I'm happy with how my HS V4 works. YMMV.
does anyone have a download link , or can send me the update.bin file for the v4?
Isn’t it on their website?does anyone have a download link , or can send me the update.bin file for the v4?
not that i can find, and not that i've seen anyone else find. i contacted the gentlemen on Whatsapp and he sent it to me, but i procrastinated and my phone crapped out before i transferred the file to my computer and i lost it. i sent him another message but haven't heard back yet.Isn’t it on their website?
I would also be interested in this. My V4 has been running on the same software from day one.
Installed new wiring looms & everything works, including the foot sensor (which is a little bit hit and miss in operation).Hansshow sent me replacement wiring looms & now the boot closes, instead of only opening
However, that is without the wires installed. Just simply loose to test connection
I’ll hold my breath until after the wires have been passed through the ribbed rubber truncheon on the boot lid - I just have a remote concern that one of the wires was crushed/stripped/damaged when fed through. I guess I’ll find out when the old wiring is extracted
For reference, Hansshow advised that when there is a software update, there is a lag with the trunk functions working
Mine took several hours to work again
Hi,I just installed a v4 trunk kit that I received last week and it seems to have a couple problems I've not seen anyone mention. First is that even though it's connected to CAN, I am not able to close the trunk from the touch screen when it is open. The button is greyed out and says "opened". As soon as I unplug the CAN wire it goes back to the old behavior of v3 where it alternates between the "open" button and "opened" text. The other problem I have is that none of the included instructions for changing the settings are working. When I hold down the liftgate button I get one beep and then two beeps, and then it stops. I can't set the speed or strength settings at all despite watching several videos. My controller also looks different than any others I've seen. There is no status light or small button on the controller, and the speaker is not a separate unit that you plug in, it is built in to the controller. My actuator also looks different than the picture in the instructions. Anyone else who just got a v4 trunk kit have any of these problems?
There are no settings on the Hansshow box to change how tightly the trunk closes to the bumper. There are rubber bumpers in the lid that can be adjusted in length to change to position of the lid when closed.Agreed, great video, thank you @Dekodan. You are right about the CAN bus and button on the screen, you have to sit in the drivers seat but also press the brake so that the car leaves Easy Entry mode, and then the button says "open" and you can click it to close the trunk. I am still unable to set the opening/closing speed, but I realized that if you press and hold the button on the tailgate, after one beep there will be a pause and then three beeps. Let go of the button then and it will set the height of the trunk door. Looking forward to the correct instructions for v6 to figure out the rest of the settings because mine definitely closes too tightly, the seams around the brake lights are way too close.
I received the same kit as you, it is in fact V6 - I confirmed with Hansshow.
Thank you, I appreciate that!
