I was really curious to find out why the music sounds the way it does when I toggle the Immersive Sound so I did a couple of quick tests.
Several people think that nothing really changes when Immersive Sound is on or off but that’s simply not true. Hopefully this will help settle that assumption. I am almost certain that no matter what the trim is, Immersive Sound works the same way.
Here’s what I did:
Test 1: turn off the Immersive Sound option first.
1) Keeping the volume about 80%, I played a track that has continuously playing strings and clean vocals.
2) All frequencies set to flat 0db in Tone menu
3) Balance white dot Y-axis (vertical) set all the way to the rear and X-axis at the center. This ensures that front speakers are not playing anything.
Now, listen carefully and enable Immersive Sound. You’ll notice that substantial reverberation and some echo gets introduced to the sound coming out of the rear speakers and especially vocals now sound terribly artificial. Disable the Immersive Sound, and the vocals and instruments are again tight and punchy.
Test 2: Disable Immersive Sound. Repeat everything as test 1 except this time:
3) Set Balance white dot Y-axis (vertical) all the way to the front and keep X-axis at the center. Meaning no speakers in the rear play anything.
Listen carefully - when you enable Immersive Sound, nothing changes. This is because the rear speakers are off.
When you combine Test 1 and Test 2, meaning when the balance white dot is brought at the dead center, enabling Immersive Sound gives us a perception of widening of the soundstage like you’re in an auditorium and because this effect isn’t added to the front channels, it still keeps the sound relatively tight and punchy.
To conclude, Immersive Sound is just the addition of echo/reverb like some sound cards offer in their equalizers (eg Creative Sound Blaster) at least in SR+ Partial Premium trim.
Premium Interior owners, you’re supposedly equipped with Full Immersive Sound. If you conduct this test, what are your observations?
Here’s what I did:
