I think I mentioned before that there are some calendar aging tests that show much reduced calendar aging at 10C compared to the data I used for my formulas. We/I also did get data from @KenC about how he ”stores it in the freezer” so to speak.I really feel like this is unlikely to be correct unless you started with an extraordinarily high capacity pack somehow. Even if it were 80kWh it’s only 5% down…
More or less any car has matched the formulas, and except @KenC’s theres a model 3 in northern Sweden (2019 I think from the memory). The owners statements did not sound right but the energy screen did prove it. After a deeper look, the car was always outside in the freezing cold and clearly was below the already low calendar aging rate I have used.
Using the data with lower calendar aging rate got that car to match the formulas, from a assumed aversge cell temp(no data present so I used the average ambient in that town and added 5C for usage/charging etc as I usually do.
I did put about this ”saving” in calendar aging from lower temperatures:
The reduction in calendar aging is ~ 30% between 25C and 10C.
I did not only use this chart but I used several others, and counted pixels in the chart to get exact values and took tje average from all these that all had about the same reduction.
There was a few research reports that did show higher reduction. Right now I did not find the picture I would like to show, but this is a projected picture of the same data:
10C cut the calendar aging in half in this case.
Also, there is a few reports testing really cold and around -20C you have almost no calendar aging.
I end up with almost knowing for sure how a battery will degrade from 10C to 50C, and with different SOC etc, but the extreme values doesn’t have very many data points (few tests) and slightly difference in the result. Having a few more results pointing into a more precise direction would be good.
Anyway, playing with the thought that we cut it in half from 25C to 10C, and knowing Ken has the car in the freezer so he’s average cell temp probably is much lower than my M3P’s, that almost always was stored in the garage at 10-12C during the winter except when used and at work. I had average cell temp 13.46C or something like that.
Let us play with 5C average cell temp, and that the calendar aging is not higher than 50% of the 25C rate, and even if Ken uses 60%, he will be on the right side of the central graphite peak after a while (calendar aging losses vapacity above the peak).
The 25C rate below the central graphite peak is around ~ 2.75% for one year, so half of this due to below 10C is 1.375%
1.375 x square root (6 years) = 3.36% loss after 6 years. Playing with that the 2018 M3LR delivered 79.2 or so in the EPA test(?) would set us at 76.5 kWh today (calendar aging only.
My formulas that are a bit conservative by purpose on the savings below 10C get it like this for an average of 5C cell temp: (still not very far away).
My takeaway from the research is that there are not any outliers really and no battery lottery in getting a car that degrades less as both the calendar and cyclic aging is predictable.
We just need to understand why we see a specific behavior.
Yes, either a 100-0 drive or a meticulous larger part of the pack drive with initial SOC/energy and as you say, the SOC at park and also the SOC after 30 minutes of no sentry/sleep and also delivered energy from the trip screen. Not too fast, but 55-60 mph or less (variations not an issue but high power will give more losses).If you do a really big discharge it would interesting to monitor energy expended (with minimal losses in park). Also interested what your park “BMS adjustments” do on that page of the Energy app, does it generally adjust upwards or downwards when you park? How much?
SOC numbers with decimal numbers from SMT.
SOC before, if the car was allowed to sleep a while (30 min or so) + SOC after the drive and after 30 min further + the delivered energy; then we can do an own probably reliable capacity calculation.
I expect it to match OK, and that there is not a big drop in SOC after the drive, but of course I too is curious
