I don't have that seal at the bottom of mine unfortunately. It is just metal to concrete.Just a thought on this - I have a garage door which has a rubber strip at the bottom of it. It can easily be closed on top of the charging cable so that you can lock the door. Maybe that's worth a try. Alternatively, you could just cut a small notch out of the bottom of the door with a hacksaw. Only needs to be about half an inch diameter.
I was thinking about the notch as you describe but my 32A switched socket arrived today and the outdoor lockable box it will be housed in with the UMC is due to arrive tomorrow so we should hopefully be wired up this weekend with a 32A supply to the car
Just need to source the appropriate wire that can manage the maximum current possible from consumer unit to socket.
Can't wait to be able to charge overnight and then precondition while still plugged in! The full benefits of the car in cold weather will be experienced next week (toasty warm in the morning )
