Inside a SpC cabinet:
I forget who first took this, someone on TMC...
Of note:
- 12 independently connected chargers that look very similar to Model S charger
- Two large control boards, possibly one for "A" and one for "B" (group of similar components on each board may be I/O for each charger, CANBUS or similar)
- Two boards seem to be chained somehow so probably one "Master" and one "Slave"
- Can't see any switchgear for each channel, but if there is to be any, it is likely to be a single contactor capable of joining channels A and B together (each channel will also need an isolation contactor - this is in case someone picks up an unused connector "B" whilst "A" is charging)
- May be arranged in banks of three going by four wire looms - complete guess but this might indicate a channel A1,A2,B1,B2 and a car can use any granularity of these to get power in 30kW blocks?
- Each group of three will be tied off a single phase to phase connection, to get ~277V to the charger module.
- - - Updated - - -
It is actually extremely compact for a 10kW charging module.
It has to:
- Rectify incoming mains power (up to 40A) which requires beefy diodes
- Filter out a ton of switching noise from PFC and converter stage
- Boost incoming mains to ~400VDC for PFC stage
- Switch this 400VDC through a transformer to the battery voltage - the battery voltage can exceed the PFC bus voltage, so it needs to boost OR buck, depending on the current battery SoC
- Do all this whilst not setting the battery on fire or electocuting anyone (control PCB's job)
Magnetics wise: there's a transformer (isolation), inductor (for PFC boost) and line filter. All are heatsunk and water cooled. There's also an output inductor which surprisingly is just passively cooled. I'm guessing it's got low core losses.
I have to admit, I was surprised to see a separate PFC stage with the associated electrolytics (lifespan concerns come into play with electrolytic capacitors.) PFC is necessary to extract maximum line current, and allows the charger to achieve PF>0.99 (with 1 being ideal.) If I were to approach this problem, I would have considered modulating the battery charging current with the line current to keep unity power factor. Would save an entire PF stage improving the efficiency and cost. I am guessing Tesla did not do this for several reasons. Primarily, it would create a ripple current on the battery pack voltage, which might impact the a/c cooling/heating (causing the pump to beat with mains frequency) and perhaps affect sensitive systems like audio and lighting. Also, perhaps it would reduce the lifespan of the battery, not sure. And there is the possibility it would not play well with three-phase multi-charger stacks, though I'm not certain.
I have seen much bigger units only deliver 2-3kW. Typical power density feasibility limits are 10~30W/in^3...
