I'm also in the "the more the better" -bandwagon at this stage, as we (tech in general) have not yet reached the sufficent level of range with electric cars. When I talk with people (on forums not directly related to electric cars) the "lack of range" always pops up. People (not yet owning or interested in electric cars) seem to be very addicted to spend their time moving ahead on the road rather than stationary on "some station" reloading their vehicle. Let alone even worrying about the whole range issue at all when travelling.
If 200-250 miles was "enough" for electric cars, then gazoline cars propably should suffice 20-25miles range compared to the station network and time it takes to "reload" in comparison. Why do we have 500 to 1000km range for cars that can be reloaded in every corner in 2 minutes?
Personally, I'm in line since 31.3. but can't pull the trigger if not close to 350 or so miles. ($20K addition compared to base range is fine). I really hope they CAN AND WILL put that in the M3
Very much agreed on most points, though from a slightly different perspective. When it comes to range, there will of course be a point where
'enough is enough' for most people. I expect that will probably be when you can drive flat-out and cover 350 miles while going from 90% to 20% remaining no matter the weather or terrain and with no regard to posted speed limits. Thus, something like a 500 mile rated range from the EPA would do the trick. The problem is...? Most people would drive the car exactly like that, stopping to fill up every 350 miles or so. If that is the case, they don't really need the 150 mile range reserve they leave
'in the tank' after each run. They could accomplish the same thing effectively in a car with only a 400 mile range instead.
It may well seem that there is a gas station
'on every corner' or on the highway
'every 20-25 miles' but these days that's not really the case. In the big, wide open spaces, gas stations are further apart now than ever before. I literally went several years of travelling without setting foot in New Mexico even once. I'd fill up somewhere East of Tucson AZ and push on through to El Paso TX, or vice versa. Those
'Last Chance GAS!' stations are all but defunct now. I think that a lot of the muscle cars from the early 1970s can't even span the distance between those gas stations anymore. 19 gallon tank, 8 MPG at speed, the car STOPS when the shadow of the needle hints at touching
'E'... You'd either have to carry a Jerry Can or two for emergencies, or plan your stops very carefully. And a lot of the spots out there are NOT open 24 hours any longer. The old timers that decry CAFE regulations never seem to remember how often they used to have to stop for gas.
I once had a car that I could reset the odometer after refueling, set to 85 MPH on the cruise control, and then I wouldn't even start looking for a gas station until I had covered 450 miles. I learned that typically, I'd find one within 50 to 80 miles after that point. It was nice knowing that I could easily cover 500-to-540 miles on a single tank
(with room to spare). And it would be very nice to do the same in an electric car. But it wouldn't be absolutely necessary, because no other vehicle I have driven cross-country had anywhere near as good fuel economy or range at speed. A lot of other cars, you need to be in sight of a gas station at 350 miles traveled, or you just might be pushing.
