There are some things about induction motors which might not be obvious:
1. The rotor is a large rotating mass with only two bearings. Any imbalance or shaft bending is going to stress the bearings periodically. If the stator windings or rotor bars are not exactly symmetrical or the three phase AC drive current not balanced then there will be unbalanced magnetic force acting on the rotor - more bearing stress.
2. All the motor torque is transmitted by the rotor bars to the rotor core, and the torque reaction is applied be the stator windings to the stator slots. The instantaneous torque varies with the AC drive frequency, so the stator winding are being rattled around at 50 Hz to 400 Hz. They had better be wedged in there tightly.
Also the electrical circuits (bus bars, fuses, HV joints, IGBTs, contactors, etc.) are subject to thermal cycling as the driver's right foot operates the accelerator pedal.
All these parts (and more) are not moving, but they are still subject to cyclic stress - this is what causes failure. A moving part not subject to a lot of stress will last forever.
