sleepydoc
Do you know what the processors actually run at? (hint - it's hotter than 150º)Would you turn on your PC at home if it was 150 degrees?
It is available in the app. Go to Climate, then drag up the bottom panel to expose more settings including Overheat.It would be nice to be able to turn on Overheat protection with the App, but that is so far not available.
Thanks for that tip, I had tried several times to drag the bottom panel up but the whole screen kept swiping upward. I just now tried again and as long as I do it carefully and slowly it works! That will come in handyt when I forget to reset the overheat when my wife is driving!It is available in the app. Go to Climate, then drag up the bottom panel to expose more settings including Overheat.
Interesting! Here is a quote from Normal CPU Temperature: How Hot Is Too Hot For CPU - CPUTemperDo you know what the processors actually run at? (hint - it's hotter than 150º)
"The average Intel & AMD desktop processors should not exceed the safe/normal CPU temperature range of 45-50°C when idle...."
That is around 122F
I truly don't understand why you guys want to have ur AC on to keep cabin below a certain temperature when you are not even in the car. I am sure I am missing something when reading this thread.
I mean when you guys had ICE cars did you leave your car running all day while you were in the office.
Please someone help me understand or educate me on this...
OK I'll try. When the interior reaches 120 and above, it puts the touch screen at major risk of serious damage. Much like fire does, heat will destroy things. It's funny how so many people here say that dark tint helps the car keep cool, it most certainly does not. Tints block light, not heat. Just touch the glass roof on a hot day and you'll understand. Elon should be putting solar panels on the roof, not glass.I truly don't understand why you guys want to have ur AC on to keep cabin below a certain temperature when you are not even in the car. I am sure I am missing something when reading this thread.
That is around 122F
The car uses a Heat pump which is so much easier on the battery than A/C to maintain the cabin at 105 degrees.
The overheat protection was installed for a purpose, that being to protect interior components inside the car from excessive heat and possible long term damage. It was not installed to provide comfort for the driver returning to the car. The most important interior component is the computer as well as the screen and thus the option to have Overheat protection as an option for those who prefer to err on the safe side. Its a matter of personal choice.Processor chips are available in different operating temperature ranges. Desktop processors are spec'd at lower temps than those made for automotive or military applications.
OK, interesting! Any references to Tesla or Elon stating that would be appreciated. 105F degrees seems pretty high for child or dog protection if that was the intent. ThanksThat's not really the reason.
Overheat protection was implemented for safety in case a child or animal was left in the car. That's why it turns off in 12 hours and why it's under the Safety menu.
Elon tweeted about this feature (in 2017 ?) and the reason for it right after it was implemented. The tweet has actually been posted on this forum multiple times.
If it was necessary to protect the components it would not be optional and you could not turn it off. Please show me in the manual where it says you need to keep the interior temp under a specified temp.The overheat protection was installed for a purpose, that being to protect interior components inside the car from excessive heat and possible long term damage. It was not installed to provide comfort for the driver returning to the car. The most important interior component is the computer as well as the screen and thus the option to have Overheat protection as an option for those who prefer to err on the safe side. Its a matter of personal choice.
I wonder if this is true. My friend just got a 2022 Model S and I noticed his sunroof is much darker than my 2021 Model Y. Did the 2022 MY get darker as well? I find the heat so objectionable that I cover the entire roof with a Heatshield product. I am very happy with the result.I guess they updated the coating or something because some of the comments about sweating and baking heads just don't make any sense for my car. My MYP is brand new and built June 2022, you can look directly at the overhead sun through it (I can’t do this with my sunglasses), and no perceptible heat comes through while sitting or driving.
Please show me in the manual where it explains the purpose of the Overheat protection. If it designed to protect children or dogs left in the car on a hot day then it should be described as such. Until someone can provide some link or explanation coming from Tesla explaining its purpose then it remains anyones guess.If it was necessary to protect the components it would not be optional and you could not turn it off. Please show me in the manual where it says you need to keep the interior temp under a specified temp.
I can’t say for sure but it’s very possible. The sunroof has always been laminated for IR and sound blocking but I know they’ve changed the lamination of the side windows so they could well have changed the composition of the sunroof.I wonder if this is true. My friend just got a 2022 Model S and I noticed his sunroof is much darker than my 2021 Model Y. Did the 2022 MY get darker as well? I find the heat so objectionable that I cover the entire roof with a Heatshield product. I am very happy with the result.
2020 Tesla Model Y SUV Windshield Sun Shades, Car Window Shades and Car Window Covers by HeatShield - The Original Windshield Sunshade
Select windshield sun shades and other car window shades for the 2020 Tesla Model Y to add to your cart. Buy HeatShield: The Original Auto Sunshade for Tesla Model Y 2020, 2021, 2022, 2023, 2024. Available colors: Silver Series Sunshade, or Gold Series Sunshade: Windshield Sunshades, car window...www.heatshieldstore.com
Elon tweeted recently about adjustable temperature for cabin overheat protection is comingOK, interesting! Any references to Tesla or Elon stating that would be appreciated. 105F degrees seems pretty high for child or dog protection if that was the intent. Thanks
