Installing a dryer outlet and installing a HPWC are two entirely different kettles of fish. For the HPWC at 72A or 80A, you'll need a $50 breaker and cable in conduit, because:
You're probably looking at something like $250 of materials depending on the length of the run -- unless it's truly short and you can nipple into the panel, or use a very short piece of flexible conduit (liquidtite).
- At 90A (72A plus the "continuous load" bump) you need #4 copper or #2 aluminum (assuming 90C terminations everywhere)
- #2 aluminum won't make the bends inside the HPWC enclosure nor fit into the HPWC's terminals properly
- You can't use any kind of large multiconductor cable except type SER inside a home, and copper SER is not available in 2-conductor #4 -- you'll have to use 4-4-4-6 which means you're paying for quite a bit of extra copper. Conduit is likely to be cheaper.
- At 100A (for an 80A HPWC, if you want to be able to charge older cars full-rate) all this is worse.
All that said, I did my 80A HPWC install myself, about 50' from the panel with PVC conduit (not allowed in all locations) and #3 XHHW copper wire. The most irritating part of the job was enlarging the hole on the HPWC to accept the PVC conduit fitting. Materials were a few hundred bucks and the job took me an afternoon -- a good electrician would have been faster than me. I would have expected to be charged $800-$1000 for the job. $1500 is out of line unless you're in a union building in a big city.
Thanks for this information, I have another electrician recommended by a fellow member coming next week so with 3 quotes and all the invaluable info from this forum I know not to get over charged!
Btw, the HPWC will be ~4 feet from the panel.
