So I went for a road trip last weekend and I noticed that the pillar vents for the 2nd row do not seem to blow air. The center console vents did seem to blow though.
Has anyone with the 5-seater noticed this?
Fwiw so folks aren't confused, you're referring to the vent on the A pillar between the first and second row seats I'm guessing. In the 5 seater there aren't vents in the back back like what a 6+ seater has
I just got my 5 seta X yesterday, and the pillar vents don't seem to be blowing much. Rear windows are fogging up. All settings are on auto. Am I doing something wrong?
Try testing it out by turning off floor ventilation and increasing fan speed. It should work. At auto, it feels like its not blowing because fan speeds may be be low and / or floor ventilation is turned on.
What did you receive in your cargo area? Vertical support panel behind 2nd row seats, floor panels?I just got my 5 seta X yesterday, and the pillar vents don't seem to be blowing much. Rear windows are fogging up. All settings are on auto. Am I doing something wrong?
It is too bad they didn't at least offer the extra C pillar "3rd" row venting and HVAC as an option. I suspect those with pets may have paid the extra.The 5 seater has vents on the B pillar (between front and rear doors) and do not have C pillar vents (I personally own a Model X 5 seater).
I know I'm hijacking the thread with my question, it's just that I'm curious if Tesla has resolved the issues they had with early deliveries of the 5-seat models. The early ones got delivered with missing parts in the cargo area.I don't quite understand the question. I haven't been following the rear area discussion. Could you elaborate?
I'm probably stating things you already know, but just to be complete, the cargo area can be configured with two floor levels. The upper level, which gives you a full level floor, with the 2nd row seats folded down, all the way to the back of the car. Or you can remove the two floor panels behind the 2nd row seats, which then gives you a taller cargo area. After removing those panels, you see a vertical support piece directly behind the 2nd row seats that supports the forward edge of the forward upper level floor panel (which also covers the lower portion of the back of the seats which would otherwise have been exposed with the upper level floor panels removed).
With the lower level floor exposed, you see that forward support panel and also the exposed well storage area at the back of the cargo area. It's been my contention that another panel was needed over the well storage area to make the lower floor completely level. The rear upper level floor panel doesn't also fit over the lower well area to make a flush cover for the well area.
So I'm wondering, one, did you get all the pieces for the upper floor level plus the forward support for the forward upper floor panel, and two; did you also get a third floor panel that fits neatly over the rear well area to give you a flush, lever lower floor as well.
In case I haven't explained myself well enough, here are some photos posted by @beths11 in another thread. She seems to have gotten the most complete version that I know of so far.
Here is the cargo area with the floor in the upper position:
Here is the cargo area with the rear upper floor panel removed, exposing the well storage area in the lower level:
Here the forward upper floor panel is removed, exposing the forward support panel that is located directly behind the 2nd-row seats:
Here is a photo that shows that forward support panel more clearly:
Here is a photo of a car that was located in Norway that shows a third floor panel that would cover the rear well storage area. There seems to be a small step down from the rear well cover panel to the forward lower floor, but this makes that lower floor almost completely level. If you will notice, that third panel isn't wide enough to be supported by the upper floor brackets, which is why I call it a third panel from what we have already seen for the upper level floor panels. I don't believe anyone has seen that third panel in this country. Following that photo is the same car with the third panel removed to expose the well storage area:
So this is what I consider to be a complete 5-seat version that I hope to sometime have confirmed by an actual delivery: a car with the forward support, two upper level floor panels, and a lower floor panel to cover the rear well area and create a level (or almost level) lower floor.
I hope you will comment on these photos as they compare to your very recent 5-seater delivery.
Others have commented about this. If you place the rear upper cover in the lower position, it end up being higher than the forward lower floor level. High enough that there is a one or two inch gap where things can roll down into the well storage area from the forward lower floor.On all model Xs, the cover for the East cargo well can be positioned either on the ledges which matches your upper position or directly over the well.
You're more looking at an extra cover in the photos, just the original cover that's in all cars shifted down.
