I get a rebate for a level 2 charger...but it may just be easier to get a 14-50 put in
So I live in Austin and they have a rebate program for getting a lvl 2 charger installed.
Austin Energy offers EV owners a rebate of 50% of the purchase and installation cost of an approved Level 2 (240V) charging station.
The maximum rebate amount is $1,200 for Wi-Fi enabled charging stations with the capability to communicate with Austin Energy and $900 for non-Wi-Fi enabled charging stations.
Home Charging Rebate
Anyway, they also state they can replace it any time which is a bit weird. My electrician I know can do the 14-50 for 300ish dollars. Im wondering if its worth it to get a fancier charger or just keep it simple. Any thoughts?
jcanoe
6,035
6,717
Maryland
If the Level 2 electric vehicle service equipment (EVSE) will be installed inside a garage then the NEMA 14-50 receptacle is probably all that you need. If your electrician can install the 14-50 for $300ish just do it. IMHO the rebate program has too many gotchas including:
  • Requires a City of Austin electrical permit and inspection for the installation of all hard-wired charging stations and receptacles for plug-in stations.
  • A licensed electrician must perform installations of hard-wired charging stations and receptacles.
  • Austin Energy may, at any time during your commitment period, replace your charging station with an Austin Energy-owned charging station located in your home and on your side of the meter.
I went with 14-50 for the flexibility it offers: since I had to pay an electrician to do the work, I now have something that I can use for other purposes or future owners of the house can use in whatever way they want. I plug in a corded mobile connector and it works great. I prefer this approach.
That last part reads so weird! It may not be worth it.
Reactions: rjpjnk and srlawren
rjpjnk
1,314
897
NJ
In my estimation the Wall Connector turns out to be only about 136 dollars more expensive, and then I get to keep the Mobile Connector in the car. I recommend the Wall Connector even without any state rebate. There is still the 30% federal tax credit on any install btw.
Reactions: Big Earl
I read your post earlier! Hi! So the thing is actually, I'm considering the wall charger now mainly because we stay with family in houston often (almost 10 tims a year), so it may be nice to leave the spare cable there. I also found another electrician who is kind of a jedi with the rebates down here so Im going to look into it. My delivery is 3ish weeks out so I have a bit of time to work this out
Reactions: rjpjnk
Talking more with the electrician, with rebates on my end its around 150 more expensive for the wall charger. So something to think about.
brkaus
8,662
7,286
Austin, TX
My electrician had absolutely no issue filing the rebate and getting me a check. Sure, it needed a licensed electrician and a permit. But those are technically required anyway.
I have had the WC installed 4 years and they haven’t replaced it. When I asked about it they were keeping it open as an option for future time of use, monitoring for future programs, or curtailment.
With that said, there is no issue with a 14-50. I have my WC set at 50a anyway (40a charging).
I do appreciate the long cord on the Gen 2 WC though.
Reactions: srlawren
My electrician is not a fan of plug-in “stove”electrical outlets. Unless “quality” equipment is used the springs lose tension over time and can cause heating/melting/fire (see internet for lots of scary failure pictures). Plus as mentioned you can store your mobile charger in the frunk for use in an emergency charging situation. Replaces that ICE spare tire you use to carry about, maybe used as much.
