Vendor I need a AI vector file.
Discussion in 'Model S: Interior & Exterior' started by Tes Pride, Dec 18, 2016.
  1. Tes Pride
    Tes Pride Former Vendor
    O'Fallon, Mo
    Does anyone have a AI vector file of the dash interiors of the Model S and X? Carbon Fiber and the Wood grains?
  2. SilentGhost
    SilentGhost New Member
    Denmark
    I have the same wish and also an AI vector file for the complete car (will be used for wrapping vinyl).
    Tes Pride - Have you got the file you wanted, if so please let me know. Thanks
  3. Acho
    Acho Member
    Las Vegas, NV
    Give me your email and I will send you AI file of the model s
  4. Terra117
    Terra117 Member
    Edina, MN
    Woah. That would save so much time.
  5. Acho
    Acho Member
    Las Vegas, NV
    And your email is?..... ;)
  6. Acho
    Acho Member
    Las Vegas, NV
    There it is. I uploaded the file here:
    http://shockwaveprint.com/tesla_vector.zip
    It is scale 1:20 so once opened you should scale it up by 2000% to have it real size.
    I use this files /not only Tesla/ for lay out prints for car wraps ant they are accurate as dimensions.
  7. Acho
    Acho Member
    Las Vegas, NV
    Just to add - this is vector file for the whole car, not the interior trim but still might be useful
  8. Naonak
    Naonak Member
    Kansas
    How do you use these for layout prints for wraps? The angles are tangential to the actual size/shape of the objects you'd want to print. I'm not sure how you'd use this vector file to crate a wrap?
    Lets say for example I wanted to create a wrap piece for the B pillar area... how would I do that with a vector file like this, since the "viewpoint" of the image is about 3 feet up and the B pillar is 4.5 feet up.
  9. Acho
    Acho Member
    Las Vegas, NV
    Not everything can be done by this template. If it is shape specific you should meaure the car to make sure everything lines up nice.
    Please note that this is very accurate template /accuracy is 1/4 of an inch for entire lenght of the car/
    From my experience using this template you can design the print to be at least 95% accurate and everything lines up as it should.
  10. apiske148
    apiske148 Member
    virginia
    Do you still have these files? Your link is no longer working...
