Those plastic clips and rivets don't hold the same if they are reused. A proper repair procedure should involve fastening everything back with new clips. Make sure they don't cheap out on that (and I'll eat my shorts if it turns out that they don't try to).
Those plastic rivets cost a few cents each, there should be no reason to not spend an extra buck fiddy to avoid the possibility of having to "fix" it again.
You might have missed my July 17th post in which I provided a pretty detailed update. Ultimately a lead tech had the car for a week and identified that the trim was not only detached due to the botched "repair" from the mobile service tech but that there were broken spot welds on the trim piece. I speculate the welds were broken during some previous repair in which they probably removed and reinstalled the dash trim.
While they had the car they tested/identified and "resolved" several other sources of rattles including further insulation of the rear deck lid. I did a test drive with the Tesla tech, who was great and I confirmed the noise of the car was livable for me. To go further the tech would have next tested/replaced the dashboard monocoque.... his concern was that in the process of replacing the dash itself, he might introduce other problems.
The car is 10X better than it has ever been. Is it as quiet as my BMW? No! Is it quiet enough I can live with it? Yes. It has little squeaking noises and occasional tapping along with the normal issues with this model such as hearing noise from all contents from the trunk more than any other car, suspension noises worse than other cars, etc.... but it's finally at the point where if I think I hear something and turn down the radio I can't reproduce it.... just noises in my head from a year of trauma I suppose.
