Can you narrow down the rattle by pressing on things when it occurs? Is it from the dash itself, or the A pillar trim? If it's the A pillar, I suspect it's the red part highlighted in the attached image. I noticed that it attaches to the dash grill without any insulation, so it's plastic on plastic. I added some felt tape to that area and it seemed to eliminate any rattle from that area.And this morning I observe I now have an intermittent rattle in the left side of the dash that wasn't there before Tesla messed with my vehicle.
Tesla continued lack of capability strikes yet again.
If it's the dash, it might be the plastic feet coming out the bottom. When I took my car into service, they added felt tape to every single feet except 1 of them. The felt tape adds thickness, so I think that caused the uncovered feet to sit differently in the slot and start rubbing against the underlying structure, which resulted in my screeching dash noise. My dash has been silent since adding felt tape to the uncovered piece.
I've heard other people have problems with the dash grill (the fabric covered piece next to the windshield). If this is the cause, then you should probably let service deal with it since it's incredibly frustrating to reassemble, especially if a clip pops loose and ends up in the vent.
The A pillar trim and dash are pretty easy to remove.
Edit: Just saw your video. Makes me think they added felt tape unevenly, so now one side sits higher than the other, resulting in that looseness.
I found some pictures of the dash on Ebay, and circled the areas that had felt tape applied in my car. The circled areas contain plastic "feet"; they're literally bits of plastic jutting out. Before disassembling the dash, I thought there would only be 1 or 2 obvious contact points where the squeaking could occur, but it turns out, the entire thing is full of contact points, so the best solution seems to be applying felt tape everywhere.
The ones they missed in my car were the far right red circle, and one of the top circles. My dash squeaking went away entirely once I added felt tape to those.
As for the dash clips, my guess is that they're metal clips that resemble these: I just got $50 Coupons! (found them mentioned on some other forum; not sure if these fit the Model 3 exactly). The way they work is they slide into the slots in various plastic pieces, and then serve as teeth to grip onto whatever part is getting inserted. They're like binder clips. The Model 3 uses these everywhere and they suck when disassembling because they have a tendency to pop out and fly into narrow places that are difficult to reach.
For my dash, I didn't look closely but my guess is that they removed my clips entirely. Felt tape adds thickness, and the feet are probably too thick to fit into the clips once they're covered in the felt tape. A downside is that the dash piece won't sit perfectly and is movable, since the only thing holding it in place is the friction from the thickness of the felt tape. But in my case, it only moves slightly, likely because there's so much felt tape everywhere.
Definitely watch the technician. If you're good with disassembling things, I recommend just doing this repair yourself once you see how it works. You'll probably be much more thorough with the felt tape, and can reapply it yourself once you narrow down the cause.
Is it like a ticking/tapping noise? I narrowed mine down to my rear right passenger door trim. The trim is several plastic pieces attached together, and there's a reinforcing rib structure at the top that is rubbing against another part of the plastic. I can reproduce the tapping sound by pressing on the top portion of the door trim (next to the window).SC investigates a tapping noise coming from passenger side of vehicle, fails to resolve (adds insulation).
I'm glad that they were able to fix things for you. I actually had a mobile appointment scheduled for today to get the ranger to hear the suspension rattling, but it happened to be raining today (terrible luck). I didn't want to chance the rain masking any noise issues like my last service center visit, so I ended up rescheduling.
Having taken apart various parts of the car, it's my belief now that there are just design flaws everywhere that result in the rattles and squeaks. There's a lot of plastic-on-plastic contact, and I expect that it'll be a never-ending battle to resolve the noise issues.
This one is tricky to fix. I tried adding some cardboard to the area secured with tape, but it's such a tiny spot that it's hard to get anything with decent thickness into that rib structure. I might try some lubricant next.
Images attached. In the first one, you can see the cardboard pieces in the areas that are the source of the ticking sound. The later two are the same area, one with a closeup of the cardboard piece, and another without the cardboard but showing the rib structure more clearly.
I have driver's side door hinge squeak and the steering wheel squeak. What lube have people used on door hinges? How to get rid of the steering squeak, it squeaks when the steering is turned?
I also think you are spot on that the car is predisposed towards these problems due to the design.
Mercedes and others have spent decades and many millions of dollars working hard to design cars that don’t have these issues.
In Teska’s Case it seems that getting to market quickly and keeping costs down have left us with cars more likely to suffer from these problems
When the rattle happens now pressing on the top of the dash, the dash trim, none of it gets it to settle down. It definitely made it so that the tech was frustrated at what could be causing it.
The first mobile tech I mentioned the problem to said that the clips that hold the trim onto the dash were very loose and she was concerned that something might be rubbing plastic on plastic between the trim/vents/dash causing the problem and she recommended replacing the clips. I'd have to see a good photo of the clips in question to understand how they get swapped but I assume they have some kind of fastener and can be replaced.
In any event, since Tesla made my service appointment for an SC in North Carolina I had to cancel that service visit and instead booked a new mobile service visit at my residence on July 8th.
My plan is to watch the tech address this by sitting there while they work on my car. There's a decent chance that I will be able to spot potential sources of the problem when they take the piece off to address the separation... even if they can't identify it because they have the brain power of a fruit fly.
