ICD Backlight
DCGOO
3,486
2,503
Indianapolis, IN
Has anyone noticed that edges of your refreshed Instrument Cluster display are washed out or dim?
In my 2022 refresh X, near the top, the upper half of the Speed Limit sign is washed out. Also on the far right, the TACC set speed limit and Autosteer icons are very dim.
I've attached a pic of the display which (sort of) shows the effect on the speed limit sign, but the TACC and Autosteer icons are not visible when the vehicle is stopped.
Wonder if my display has a problem, or if this is typical?
I have that too. Seems to be typical.
I imagine they will change the layout in the future and move icons closer to the center of the screen to avoid this.
The old displays don't have the frosted edges like the new displays do so I think that's where the "bugs" happened.
Change your tire size and the screen will reboot showing a white background. You'll see the "digital frosted edge" like below.
Upvote 0
Yep, your pictures look exactly like mine. Thanks for the confirm
Upvote 0
