Does the outside temperature display a temperature that is clearly wrong? The outside air temperature sensor is located in the right front wheel well. The wiring for the sensor is vulnerable to rodent damage. Have Tesla Service check that the sensor and wiring are OK.Yes, I have also noticed that running in manual mode like that is sometimes better, but then we lose the automatic adjustment of parameters like fan speed, recirculate, air air distribution as heat load changes, which are typically are great to have. At least that has been my experience in other cars.
The system is plenty powerful, just not regulated well. The problem is more often excessive cooling, than a lack of it, but I do experience both at different times. I am using an opaque sun shade on the roof (Heatshield) in Summer and that definitely helps a lot.
But really, like I said, there is so much I love about this car I have just learned to accept the poor climate control. I like to keep the thread alive because I still have hope that if it gets enough attention Tesla might release a software update to fix it. I know they have made some progress.
I had my '20 MYLR sensors replaced recently via the service center due to this service bulletin but I'd swear that my AC works worse now than it did before. It takes longer to get cold. :-( Of course it might be a coincidence with the 110°+ degree days here in AZ... :-O Just seems like it was better before the sensor replacement... just my $.02I think we may be talking about two slight different issues here. I'm not sure what this super manifold issue is, but the temp sensor issue is something which I've heard about for several months now.
I think bottom line for the op is that what you are reporting does not appear to be normal, and you should have it checked out.
Hopefully Tesla will be able to get it resolved for you between the sensor replacement campaign and/or diagnosing any other potentials issues.
The outside temperature displayed on the screen looks correct. I have added a UBD2 port and in the past have logged all the temp sensors I could find. There are many. Even the roof has a temperature sensor. That's why I am frustrated. With so many temperature sensors, and even humidity sensors and fans to draw in cabin air to help them be more accurate, and the super advanced octovalve system with all of its monitoring and feedback, they can't seem to maintain a comfortable consistent temperature in the vehicle. I suspect this could be resolved with some software tweaks if someone put the time into it. As I mentioned, the AC is plenty powerful and can certainly make the car plenty cold, it's just not regulated well.Does the outside temperature display a temperature that is clearly wrong? The outside air temperature sensor is located in the right front wheel well. The wiring for the sensor is vulnerable to rodent damage. Have Tesla Service check that the sensor and wiring are OK.
Has the windshield been replaced, possibly before you took delivery of the vehicle? Tesla Model Y owners who have had to replace the windshield sometimes have climate control issues after the replacement (the wiring for the cabin temperature sensor is either damaged or not correctly re-installed as part of the windshield replacement.)
I usually use manual mode. 68 degrees, recirc, fan between 6 and 8 if it's hot out to keep the air circulating. If the fan is below 6, there is too much temp variance where the sun shines in.The outside temperature displayed on the screen looks correct. I have added a UBD2 port and in the past have logged all the temp sensors I could find. There are many. Even the roof has a temperature sensor. That's why I am frustrated. With so many temperature sensors, and even humidity sensors and fans to draw in cabin air to help them be more accurate, and the super advanced octovalve system with all of its monitoring and feedback, they can't seem to maintain a comfortable consistent temperature in the vehicle. I suspect this could be resolved with some software tweaks if someone put the time into it. As I mentioned, the AC is plenty powerful and can certainly make the car plenty cold, it's just not regulated well.
If I were to sum up the problem after much observation I would say the system is having trouble sensing the cabin temperature, and therefore producing the wrong output. Sometimes too hot, sometimes too cold.
It seems that there is. When I switch from auto by manual by changing the fan speed, the recirc button turns a pale blue (vs grey for off and deep blue for on). I think that function is still auto, but I'm not sure.I am going to try experimenting with manual mode more as well.
I wish there were a way to adjust the fan speed and still keep the rest of the system on auto. Maybe there is now? I haven't tried in a while.
I have observed the pale blue recirculate cabin air button. As far as I can tell the button colors, settings include:It seems that there is. When I switch from auto by manual by changing the fan speed, the recirc button turns a pale blue (vs grey for off and deep blue for on). I think that function is still auto, but I'm not sure.
Same situation here. June 2020 MYP. AC/Heat were amazing for 2 years. Tesla strongly recommended sensor replacement due to bulletin (I’d declined it a few months prior). Afterwards, immediate degradation in AC. Takes way longer to cool in general, and have to drop the temp into the low 60s on Auto to have any substantial cooling effect. Previously could set/forget at 68/Auto even in the FL summers.I had my '20 MYLR sensors replaced recently via the service center due to this service bulletin but I'd swear that my AC works worse now than it did before. It takes longer to get cold. :-( Of course it might be a coincidence with the 110°+ degree days here in AZ... :-O Just seems like it was better before the sensor replacement... just my $.02
No, I have not been back to the service center yet. Let me know if you get any satisfaction from them. thanksSame situation here. June 2020 MYP. AC/Heat were amazing for 2 years. Tesla strongly recommended sensor replacement due to bulletin (I’d declined it a few months prior). Afterwards, immediate degradation in AC. Takes way longer to cool in general, and have to drop the temp into the low 60s on Auto to have any substantial cooling effect. Previously could set/forget at 68/Auto even in the FL summers.
Did you end up getting this addressed? Planning to make another appt…
Take a look at mu recent post. Beware they can noy see the problem,OP here. Tesla service just texted me to ask date and time it occurred. Are they going to read my car’s logs remotely? How can I best respond to them in order to get this fixed correctly?
Insist that they test the car to compare to spec.Take a look at mu recent post. Beware they can noy see the problem,
