Firehuntah
Well, KW told me hls won't work for some reason on m3 coilovers (not enough space), but maybe they wrong.
As about side loading, it's all about designing for that, I guess. Dampers themselves are hydraulic cylinders with high momentary pressure. But they solve it with the use of long seals. Which we don't have much space for. I'm sure that KW knows how to do hydraulic cylinder that won't leak on a car...
True yeah. Perhaps it will be fine. But I've done enough experimenting with the air cups. Don't want to start all over again with HLS. Maybe you can try it! As for them mentioning there isn't enough space.. I believe there's plenty of space for the HLS kit, Model 3 offers a lot of space inbetween the damper and knuckle. I don't think it'll be a problem really.
pillowballs be pillowballin'
How loud are the clunks compared to tire impact noise? I have spherical top hats on my coilovers. I hear the pillowball clatter on bad roads but it's mostly drowned out by tire impact noise (which was loud on this car stock, and stayed that way with the coilovers). On smoother roads without tire impact noise I can't hear the pillowballs at all thankfully. It's about the NVH level I was expecting from new, good-condition pillowballs - which is to say a little bit, not zero, but not excessive.
Yep.. the one thing I just don't like with pillowballs. It's just so noticeable on an EV where everything else is pretty much silent. But on mine it's actually quite loud, but only on bad roads. On smoother roads I don't notice it at all, stays silent. What coilovers are you using and why did you get pillowball mounts? I'd personally much prefer the OEM top mounts for reduced noise. Though I do really like the feeling with the pillowballs. Of the added NVH it's really only the N part that bothers me.
