Installing Wall Connector is better than NEMA 14-50
Perhaps you were referring to the Mobile Connector. The Tesla Gen3 Wall Connector is designed to be hard wired and does not come fitted with a power plug. Tesla does not provide installation instructions for attaching a power plug to the Wall Connector, so adding a power plug to the Wall Connector (which some have done) does not meet code. The Tesla Gen2 Mobile Connector is designed to accept different power plug adapters. The NEMA 14-50 power plug adapter for the Gen2 Mobile Connector enables charging at 240V and up to 32 amps.
I have a Juicebox that was installed, but the electrician also installed a box with the 14-50. I'm not talking about using the cable that came with the Tesla.
I had the wall charger installed in my garage. A popular local electric company charged me $1,200. I only went with it because a quote from electricians on Tesla’s website was like $2,000.
But I feel like that’s way too much right? My house is a 2016 build and it only took him one hour to install it.
Does seem like a lot...I paid $500 and included all material (except the wall connector). Took him a couple of hours and I thought I was paying lot.
I agree seems a touch steep. I paid $750 to get mine installed and that included a requested inline disconnect. I used a smaller local electrician but he is Tesla certified instead of the big name company in the area that wanted $1800.
Understood. Thank you.
Here is what we have. Parked next to this is our Challenger, because that makes sense :)
The box has the 14-50 outlet that the Juicebox is connected to.
Did this bill include the cost of the wall charger itself? For such a short run the 1200 price seems way too high to me. Did you get an Itemized receipt? Maybe it shows why it was so expensive.
It did not. It was done by the big name electrician in Dallas so maybe that’s a part of why it was pricey. I don’t have an itemized receipt. I asked him why it cost so much and he just said that’s the price corporate decided on.
On the bright side, I love the charger so far. Very fast.
I have posted this before in much earlier threads. When I had my Tesla wall charger installed in my garage in 2020, I had wires pulled for a future Nema 14-50 at the same time from the box to the garage, since holes in ceiling/walls were already being made for the pull-throughs. It added very minimal cost to the job, and made adding the 14-50 a breeze later.
I've "owned a Tesla for a number of years" and never used a Wall Connector. Funny how I never needed the increased speed when I charge overnight, as my charger will top up my tank easily while I'm asleep. I've been charging exclusively with my 220 volt outlet for the past ten years and never been hampered by lack of charge. Plus, I can plug other things into my outlet.
Sure, your Walll Charger is a little faster, but who cares? My car is full every morning, just like yours. Plus I can plug other items (small welder) into my outlet and use it for other things. In ten years come back and tell me how your "fast" charger has helped you. Unless you're terribly disorganized and don't remember to charge overnight, you've just wasted your money, but with the money I've saved I just bought my wifey a Model 3. As I was building my garage at the time I installed my 220 outlet, I spent only a few bucks on it. And if you're disorganized, I doubt you have much money to spare.
I have found ZERO need to charge faster at night. But, hey. Maybe the Wall Charger looks cool to you. Doesn't do it for me.
Agreed! And with the Wall Charger you would need to upgrade the main electrical panel to 200A. A 100A e-panel may not adequate for adding the wall charger. I have a NEMA 14-30 outlet installed and charge my M3LR at 24A overnight (9PM-6:30AM), its tank is filled up to 85% before 6:30. I thought the Tesla level 2 charger has a built-in GFCI therefore, a GFCI breaker is not needed. So far so good, no circuit breaker trip, the charging plug and connector are a little warmer than room temperature after serval hours.
GFCI is required because the charger is not hard wired and other things can be plugged into the outlet. Because its an outlet it needs its own GFCI protection to meet code. If the charger is hard wired the built-in GFCI negates the requirement for a GFCI breaker. The built-in GFCI of most chargers is one of the reasons its better to hard wire. If the charger has built-in GFCI and you need the GFCI for your 14-50 or 14-30 outlet then you have two GFCI on the same circuit which is a recipe for nuisance tripping.
You can set Wall Connector to any amperage you want. And it doesn’t cost a $40 adapter to flip it. I have my Wall Connector on a 100A service no problem. And when I upgrade the panel I just twist the switch to the the rating I want.
As OP states Wall Connector is the way to go.
Most folks that say no to Wall Connector never had one and don’t realize what a more elegant solution they are. Like the comment above requiring 200A. In fact I think Wall Connector has a wider range of options than the Mobile connector does. And you can change it later.
The GFCI built into the Mobile Connector (also the Wall Connector) is there to protect the user when plugging the Tesla charging connector into the Tesla vehicle's charge port. The GFCI circuit breaker (or GFCI receptacle where available) is there to protect the user when they plug or unplug the equipment from the power receptacle. If you were installing a new 14-30 receptacle today for EV charging the electrical code specifies that it would need to be protected by a GFCI. Some receptacles are available with built-in GFCI, else you would use a GFCI circuit breaker to be compliant with code.
It really is hard to believe that even with the mobile charger no longer being supplied free with the vehicle *and* the Wall Connector dropping 100 in price some people still seem to prefer the mobile connector. I have both and use both, and can't imagine why someone would prefer to use the mobile charger given the choice. One argument I hear frequently is that installing just an outlet is more flexible because then you can plug some other charger into it if you sell your Tesla or your house. But it is almost just as easy to replace the wall connector with an outlet if that ever happens. I love the wall connector. It's convenient, safe, stylish, and now even more affordable. The mobile charger works well too and I am glad to always have it in the trunk incase I need it somewhere.
Use case for 14-50 outlet:
You have two EV’s and one is not a Tesla. It would cost $3K to run a second circuit 100+ feet through the home and into the garage.
We use a “Y” splitter and have two chargers plugged into our 14-50 outlet and take turns charging. If I could wire a 14-50 cable into the back of the wall charger I would, but that is technically not allowed.
It has a purpose.
  • Disagree
Reactions: davewill
It has a purpose.
While it works temporarily that is not a good solution especially using the Y cable. In your situation I would put a sub panel in the garage.
Not saying this about you C Bus but generally speaking I can’t understand why some folks choose to spend over 60k on an EV but try to cut costs with their home charging. Charging should be the number one consideration when purchasing an EV. A potential EV owner needs to figure that piece out before purchasing the EV. I can’t stress enough how important safety is with EV charging. This is NOT a place to try to cut costs or save money.
I have BOTH, a hard-wired Gen 3 WC in my garage, and a UMC with a bunch of adapters in my FRUNK. The NEMA 14-50 was installed when we built our home in 2018 when we had a CC with a 25' cord and cost about $200 to install during construction (the builder has since started including it) and I paid $334 a few months ago to hardwire a WC with 24' cord. I tried living with the UMC and 20' cord but it was too short by a couple of feet.
The 4 extra feet on the WC allows my wife to pull in on the right side of our garage and the 24' cord safely reaches the charge port. Else she'd need to back in on the left side. Lots can go wrong with that plan.
Reactions: 240vPlug
Thankfully mine came pre-installed with my house too and its right at the back corner so my wife can pull strait in. Otherwise it would've been a horrendously long run through the attic and I'm to old for that.
